Thanks for the hot tip on the hot tips!
Got one…$17…woot!
Got one…$17…woot!
From Vipon:
“LUMINTOP Bike Tail Light Type C Rechargeable BT1 4 Modes Rear Bike Light Max Runtime 10 Hours Type C Charging Port IPX-4 Waterproof Bicycle Tailight”.
I don’t ride a bike, but I own one of these and they’re nice to have for walking so you can be seen when it’s dark. It ends up being closer to $6 with the additional coupon.
https://www.myvipon.com/product/8921704?sl=3d11aa126bd62513c138b0d8b04be71a
Well done. Came here to post this….still going.
I received this USB hub today.
It seems to work fine.
The main complaint in Amazon reviews is that it gets quite hot, but I won't be charging a bunch of stuff like some people do, so maybe the heat won't be a problem for me.
UPDATE:
I've had six external hard drives plugged into this USB hub for twelve hours, and the hub is nowhere near hot.
So I think the hub will not get quite hot unless you do something like try to charge ten tablets at the same time.
I got pairs of kids gloves as well.
On Vipon this morning.
3V? Is this for Arlo cameras only?
Pulled this info from Amazon review. I bought a set to try in my 3v CR123 lights.
These are 3v regulated and not like your normal rcr123a
Reviewed in the United States on October 9, 2021
Some observations: Arrived with 3 of the 4 batteries < 3.0v and off via protection, was able to activate them on my charger and measured 2.7v so ok. Don’t try to charge these on a conventional charger as they never stop as are regulated at 3v and don’t reach 4.2v to stop the charge cycle. Must use the microusb port to charge. Observed that if overdischarged and protection enabled the usb charge port does not reenable the battery, had to enable on a charger before would take a charge via usb. Charge rate on the port is 300ma.
Amazon/Woot/Whatever….
$8.50 to have and to hold.
BlackHawk CQC Compact Light Carrier
Many thanks … I snagged two.
BORUIT LED Magnetic Flashlight, 2000 Lumens Tactical Flashlight,90° Adjustable-Head $14.40
WARSUN LED Flashlight Rechargeable Tactical Flashlights High Lumens Bright Flash light Camouflage Torch
$12.99 and a 20% off coupon —
Not much info on Amazon but looks to be the same as this one on Aliexpress
I have a couple of these, not really a big fan. They sit pretty far off your belt but the problem is really how hard it is to draw the light. Lets just the retention is…excellent.
Multi-functional Flashlight with Lantern IP65 Waterproof LED USB Rechargeable 2500 mAh Powerbank Portable Camping Light with Magnet
$16.13 and an additional 30% off coupon
Coming up as $15.99 for me ($3 less if you have Amazon Prime). LINK. How weird that the Amazon listing has key info missing, like emitter and battery details. A CREE T6 sounds old. I’m guessing cool white.
I have prime so I see the $12.99 plus 20%
From what I see in the Amazon pic — the led has 3 bond wires XM-L ( very old) these lights most likely have the crappy pill and tail switch — Been there Done that
