[Ongoing] Deals for IF22A in Black and Sliver on Amazon.us
Hello, I would like a code as well for the IF22A. Thanks!
I’d like a code please
I would like a code please.
Cuz the stock is limitied, so the codes will be delayed to send to you, thanks for your patience. I’ll send the code to above who had leave a comment. Thanks for your patience again.
Same here. I need a new code. Someone else must have used the code before I could. :rage:
Looks like I’m late, but if there’s still one available I’d like a code please.
Too late? :frowning:
I’ll take a code if there is still one available. Thanks!
Sofirn,
I would like a discount code for IF22A Silver, to order from your Sofirn Official Store.
Does sofirm have USA stock of this item? Need link please
Received my IF22A - the battery charge level indicator is not working properly. It shows steady red, right after fully charging the battery inside the flashlight for several hours and turning the light on. I know the green LED works, as it shines green after fulling charging the light. I’ve fully tightened all of the connections - it is still steady red when I turn on the light. I’ve also tried opening up the light and removing the battery, then re-inserting it. Looks like this light will need to be returned to the seller. I’m very disappointed, as it seems like a great light, other than that problem.
I’ll work it out for you, please check your message, thank you!
Please check your message.
The link on main thread is to Amazon.us
Thank you very much. The seller has also reached out to me for a solution. I appreciate your company standing behind your product and doing the right thing to resolve the issue.
If the Amazon coupons are out. I have no issues ordering direct
Can I still get a code?
Thank you for the code, ordered one.
May I get a code for black?
