Sold separately handle mount to the tail, I didn't think of that, I like it.
So now My wild Idea base on that and current design, to allow for it.
Make that grooves on the battery tube at angle, and make a big thread out of it. The handle would just screw in it, and have a holes (3 or 4) for couples screws or something, to threads through it, and go in that 7 or 8 (from render i count 7) larger oblong groves in battery tube. So you can lock it into place, that holes in base of the handle would have to be long vertically, so you can lock the handle directly over the switches. That design could allow that. That Nitecore have just 2 part base handle, but i think it's weak, you just need a long vertical hole of size of length between the large oblong groves )
Of course, the portion before the start of the grooves on the battery tube, would have to be shallower, than threads.
That design would allow for the handle to be moved closer, and further, from the switches, as well, to move right and left from them. So we can have one handle for large and small hands, and you can move the center of gravity to your preferable spot, for handle.
And the locking screws would not be load bearing, it could be screws with rubber tip, to not scratch surface. Or some other type of rotation locking mechanism.
There Is also one handle design that would work with the current design, just have a hinge, and a screw, to lock the base of it to the tube.
Ps. saw this now, a TIR optic, and single battery (which is probably bad idea, but then again, he probably used his NOCTIGON K9.3 base)
I heard rumors about the XHP50.3 but I didn’t know there would be a flat version. What can expect from this emitter and how would it compare to something like the SFT40?
So far I am loving everything about this prototype and I look forward to it’s release. If I could suggest one thing, it would be to offer SST-20 2700k for the flood emitters. Keep up the awesome work!
Better will be LH351D 90CRI. It is more floody compared to SST20 and have great choise of colors compared to only 4000K for SST. Also LH351D has better efficiency compared to SST20.
any changes of plan, for the dual switch, now that the Anduril tint ramping and instant channel switching firmware is out there (looking at the hank KR4).
