d_t_a
(d_t_a)
October 15, 2021, 7:00am
286
Jackie, would you happen to have a tool to help in unscrewing the SP40 bezel?
I have removed the bezel from an earlier SP40 (XPL-HD) before (it got a few scratches).
but when I tried to remove a newer SP40 (LH351D), I had trouble removing it (I do not want to scratch the bezel…)
Kos70
(Kos70)
October 15, 2021, 3:54pm
287
d_t_a:
Jackie, would you happen to have a tool to help in unscrewing the SP40 bezel? I have removed the bezel from an earlier SP40 (XPL-HD) before (it got a few scratches). but when I tried to remove a newer SP40 (LH351D), I had trouble removing it (I do not want to scratch the bezel…)
Try to turn on Turbo for a couple of minutes, and unscrew it by resting on slippers or a rubber mat ... I did just that, and it was with SP40 (LH351D)
mattlward
(mattlward)
October 15, 2021, 7:06pm
288
Can you tell me about the PWM on this SP10V3.0? I had one of the older AA/14500 lights and the PWM was so bad that I gave it away, gave me a headache.
Jackie
(Jackie)
October 16, 2021, 2:05am
289
will check with our engineer on Monday
Jackie
(Jackie)
October 16, 2021, 3:16am
290
get a reply now : about 20khz
Serlite
(Serlite)
October 16, 2021, 3:26am
291
d_t_a:
Pressing it into the bottom of a mouse pad or a rubber jar opener has worked well in my experience.
I started off using snap-ring pliers, and also scratched the bezel. Then I found out friction is often enough, and it made modding a lot easier.
Jackie
(Jackie)
October 18, 2021, 9:58am
293
max
(max)
October 18, 2021, 3:36pm
294
Thanks Jackie, orders placed.
Jackie
(Jackie)
October 21, 2021, 8:34am
296
IF22/IF22A/TS21/SC31T/LT1/SC21/SP36PRO/Q8PRO/FC12/DL10R/SD05/HD20/SD01PRO/HS05/WK30/S11
Code for all models above : L9BWVAC5IN0T
The old code did mot work. Do you have a new code for the New SP10V3? Thank you
Jackie
(Jackie)
October 22, 2021, 8:17am
298
L9BWVAC5IN0T update this one for SP10V3
Just tried code for the IF22A on Amazon US and it did not work. Do you have another code? I would really like to purchase this light! Thank you
Jackie
(Jackie)
October 24, 2021, 6:30am
300
Amazon code was ended, here update a 15% code on Aliexpress : AID9YVQUARKK
Jackie
(Jackie)
October 27, 2021, 1:44am
301
Jackie
(Jackie)
November 8, 2021, 11:23am
302
1.From 2021/11/11 00:00 and 2021/11/12 00:00, the first 30 persons who order successfully will get a free gift ,send together with your order.
2.Order amount more than $100 will have a chance to get a free gift.
3.Add to your cart first, then you will get many different coupons from our Shop
More unlimited coupons will update here
1stein
(1stein)
November 8, 2021, 11:25am
303
Thanks Jackie. Which time zone are you referring to?
