You got mail.
Hello, interested in the code.
Thank you Freeme, just ordered one.
Ordered one, but it says the is no stock.
I’m interested in the code. Also, it looks like the ‘can’t wait’ code expired.
Estimated shipping date will be around November 15.
Has anybody found a suitable holster/case for the WP3 at all?
I’m pretty sure it wouldn’t fit. Although I might get one anyway to try, and use it for my FT03 if it doesn’t work.
FT03 = length - 170mm, head diameter - 69.5mm
WP3 = length - 184mm, head diameter - 59.5mm
Holster has room for extra 14mm but it will be tight fit though.
ASTROLUX WP2 185mm
freeme:How about FT03 holster?
TMaxxJJ:Has anybody found a suitable holster/case for the WP3 at all?
I’m pretty sure it wouldn’t fit. Although I might get one anyway to try, and use it for my FT03 if it doesn’t work. FT03 = length - 170mm, head diameter - 69.5mm WP3 = length - 184mm, head diameter - 59.5mm
I’ll give it a try, thanks Freeme
Interested in code, too!
Just received mine and it is a crazy thrower. Just curious if anyone has tried the 26650 battery in it yet. As you know it comes with a 21700 battery and various reviews indicate that a 26650 battery will work as well. However the owner’s manual makes no mention of the 26650 battery only the 21700.
Used a 26700 and it worked fine as far as I can tell; not that I use the light much as I don’t want to frighten the good citizens of the neighborhood.
Any recomended 26650 battery?
Thanks in advance
VapCell INR 26650 5500mah 20A (2021)
https://www.aliexpress.com/item/1005002424304589.html or similar 26650 with 15A?
Any recomended 26650 battery? Thanks in advance
Hi Freeme. Please send code. Thanks.
You got mail!
You got mail!
Pilotboy:Hi Freeme. Please send code. Thanks.
Ordered. Thanks for the code freeme!
This is going to be my first LEP and I simply can not wait for it to arrive!
My current longest throwing torch is the Convoy L21a CULPM1.TG.
You won’t be disappointed. It still makes me laugh every time I turn it on!
