Certainly if the optic fits. Certainly not if you use the original optic. Maybe good to have an xml2 as backup. It’s not a very hard mod to do btw, just work your way around the bezel with a knife to open it up. Have you seen the video by - X3 - ?
I tried the optic over an 219 when I opened the light the first time and it was not nice enough for me. I have a feeling Jon is a bit snobbish about his beams also.
yes, Ive been reading the teardown threads, including for the S1 Mini… which is where the Yaji Tir are mentioned.
And Ive read that the main obstacle to a S Mini mod to 219b is the stock XML2 Tir… hence my interest in a Tir swap to Yaji 3535 profile.
Ive not confirmed if the S1 Mini and the S Mini use the same size Tir, but I did read that the 17mm Tir fits the S1 Mini.
Urban Widsom or Urban Legend…
I trust Geuzzz, since hes actually done it, and also X3…
so… just covering bases…
I can start with a 219b in the stock XM Tir, to confirm how horrible it is…
then have a couple backup options:
backup Pebble Tir,
backup XM-L2 LED
I’m using an original OP reflector from an early version Niteye Eye10 in my TCR-01 with SST-20 right now. I quite like it.
The beam is pleasantly smooth with good throw. Sure the outer edge of the spill is slightly brighter than the rest of the spill, but it’s almost unnoticeable…. even in a white wall test. In real-world use I don’t see it at all the beam looks perfect. I have many lights with orange-peel reflectors designed for their emitters that look much worse.
In my older RRT-01 I currently have a different OP reflector which I purchased from Kaidomain years ago (I think). It gives an even more uniform beam than the Eye10’s beam, but has a noticeably dimmer hotspot.
My original RRT-01 and TCR-01 both came with the same smooth reflector that was absolutely horrible. It produced a horrendously ringy beam even with the XML-2 emitters that came with those lights. Yuck!
It’s a mod! This has been done a lot to firm up the feel of a switch or make it more responsive without going to the trouble of replacing it with a different switch. An easy way to to use some hot glue on the plastic plunger of the switch itself, then you can trim it to suit with a razor blade. A suitably thick plastic disc can be punched out with a paper or leather hole punch and glued on or just tucked in there. Even easier sometimes is to use a different switch boot that has a nubbin attached to it…use it as-is or trim it down a little bit. Something like this type:
For fine tuning the gap between the top of a clicky switch and a button boot I recommend the following:
Layer up small pieces of tape on the tip of the switch.
I tend to use Gaffer’s Tape or 3M Safety Walk Tape. However, any tape will do…. even masking tape.
The tape doesn’t need to be strong. It won’t come out of position with use since all the action is straight down into the tape. There’s no lateral force.
Using tape gives you very precise control of the height of the switch without affecting the feel of the rubber switch. It’s also easily removable and adjustable.
For me, switch feel is soo important. I totally get it. Forward clickies go on basically every light that isn’t an e-switch and proud, hair-trigger setups are my favorite. These are usually always throwers with one mode or dual switch or no mode memory, turbo first. I approve
I repaired the driver today. Beamshots of the two:
V10R Ti+ sw45k on the left, RRT01 sw30 on the right. As you can see, the beams are pretty good. The RRT-01 has a wider beam, and overall it’s slightly better. The VR10 has a bit of a bright ring at the very edge of the spill, but that’s really the only “flaw” in the beam as far as I can tell - and I don’t mind it in real use.
The V10R Ti+ is as low as it’ll go (which is plenty low), but the RRT01 is already dimmer and has more room to go. I can get it dim enough that I can only tell it’s on if I’m not looking directly at it.
YES, yes it is. The beam is.. well.. bleh. not good, right now! ive put all of 45 minutes into the light so far though, non of which has been working on the reflector location. I need to drop it. and center the reflector of course. i just wanted to get it together to try it out tonight. lol.
But yes, the off center led makes the beam not have a hotpsot essentially. at 20m you see the hotspot, but its not defined.
thank you, I will try that. I think I already did it on this one but I don't remember because I might have a couple lights yesterday and on some of them I sanded the centering ring really thin. So I may have done it on this already but I will try if I did not.
and absolutely about the short possibility. I surrounded this sbt90.2 with kapton tape, which I always do when I Delens them, just to be extra cautious . So this one is insulated pretty well. This is the first time I noticed a green tint coming from the delensed sbt90.2, though. At least on lower levels.
I got it from Simon at convoy I wonder if it's just the particular batch..
