Emisar D3AA is available now
Do we know when theDM11 comes out yet? Anyone already have any experience with the Nichia B35?
According to this Reddit post it’ll be released “next month” (November) and there will be a pocket clip available.
Yes, that is true, the 26800 tube should be available by November.
There are no other 26800 project plans.
I think I might be getting a dm11 b35. Looking forward to seeing final specs and finishes. Curious how it’ll compare to a d4s 26800 with sst20s.
Thanks!
I have plenty of B35AM and B35AR and so far they are my number 1 emitter in both 90+CRI and output ( 1500+lumens).
They are big bro's of 219B and E17/21.
Do you plan on offering 28600 cells (QB26800) with this tube ?
I found one seller (with not so good ratings) on AE but it’s quite expensive and 2 months shipping.
There is one US seller but international shipping is expensive.
Will there be a option to order the new leds(B35AM and SFT-40) when you release the DM11? How much would the shipping costs?
Would it be possible to get SFT40 in the K1?
We do have the option, only that SFT-40 LED is not available yet.
Only that the throw is not that great, I measured about 25kcd throw on high.
It’s the throwiest of all Nichia’s so let’s say it’s a good one
It’s actually right on par with a maxed out 219C, which believe it or not is the previous ‘thrower’ of the 9050+ Nichia’s. Due to the quad die structure, the 219c might eek out a win.
In the end, I think a quad 219c under ledil angie vs b35am under 35mm single optic is going to be an interesting comparison.
D4S vs DM11. These are my estimates, some of which are based on Hank’s previous comments or specs on intl-outdoor
Max W 60 vs 22.5
Max kcd 20 vs 25
Max lm 3000 vs 1550
lm @@ 20W 1600 vs 1500
kcd @@ 20W 11 vs 24
cd/lm 6.7 vs 16
spot angle 18 vs 11
I know this is Blasphemy to mention another Brand, but there is another popular light with a 35mm head, single optic, with slightly frosted center that uses the xhp35 HI, that is only capable of 22,500 cd (with a 5500k emitter mind you).
All of that to say - if the BM35a is as nicely tinted as i am hearing, and the CRI is high, then 25kcd is actually rather good i would say! considering all of the information.
What will the throwiest LED offered be on launch? I was planning on ordering it with the SFT-40, I’m afraid it wont offer much over the KR1 other than aux if it doesn’t have a more impressive emitter than the W2.
Any idea if the flashlight will be released in the coming 2 weeks or not?
I don’t remember where I saw the post on the buck driver, but it’s what made me interested enough to post. I assume it was on BLF, but I occasionally check Reddit for news on Hank’s lights. Anyway, Hank said the DM11 would use the same boost driver that was already used on the XHP35 Hi K1.
Hank do you already know what will be the throwiest option for the DM11? Will it top the KR1?
The throwiest option will be Osram CSLNM1. If it’s driven to peak brightness (4-5A) we should see ~160kcd from it with this optic. The beam should look virtually identical go Acebeam E10 and Thrunite Catapult Mini, it’ll just be a little brighter hopefully.
KR4 tint ramping version is available for now,
https://intl-outdoor.com/
D4V2 tint ramping version will be available as well.
Awesome!
