I’ve created a new post here with some of my thoughts on how Convoy’s user interfaces can be improved. I would love for the rest of the community to take a look and tell me what you think, and I also hope Simon will take a look and see if any of these improvements are feasible.
Hi Simon, it has been more than 2 months since the announcing of Quad TIR and it’s production.
How is the progress?
I got the sample some time ago, and the host is already in production.
Nice… :+1:
Hey Simon,
- Any idea when SFT40’s are going to be back in stock?
- Also, do you have any plans for adding charging to more lights, such as the M21B?
- Will the Remote Tail Switch for the L21B also work for other lights, such as the M21B?
Thanks a lot for how you help the community!
Simon,
I recieved my M21e today, such a nice light!
I installed my sft70 LED in the s21b xhp50.2 light and it worked fine on mode 1-3, turned blue on mode 4 (100% output).
I then installed the SFT70 into my m21e and it worked up until about 75% ramp, then turned blue and the light started smoking. I thought i blue the sft70..
But now my m21e wont turn on with the xhp70 in it either. I put that back in and it wont work.
Can i buy just the driver for the m21e from you?
does anyone know what i did to my driver? i wouldve thought that just the led would burn out if anything, and i was completely OK with doing that for the sake of expirementing.. I didnt think it would ruin the driver..
Anyway.. TIA
Simon, any idea when SFT40 will be back in stock?
even for sale in your lights again -
Lights with sft40 like the m21a, m21c, or L21a?
Thank you!
Simon,
I then installed the SFT70 into my m21e and it worked up until about 75% ramp, then turned blue and the light started smoking. I thought i blue the sft70…
does anyone know what i did to my driver? i wouldve thought that just the led would burn out if anything, and i was completely OK with doing that for the sake of expirementing… I didnt think it would ruin the driver…
Anyway… TIA
I always check if I put led wires wrong way if nothing happens after install. Or if you reflowed it to pcb 180° wrong way.
I got my AA/14500 13 group drivers, I also got an orange T3 with an SW35. The stainless screw on clip is way better than the stock clip.
The wires on the 14500 driver are backwards. The red is negative and the black is positive. All three were this way.
Unfortunately I broke one of the drivers tightening the retaining ring in my Jaxman E3. The pliers slipped and broke some stuff off the back of the board. Double sided drivers may be unavoidable, but they are annoying.
I also put one into a Thorfire TG06, It works perfectly in that light as well. It’s also sold as the Alonefire X380. Same host with slightly different reflector.
How is rosy sw35 from Convoy compared to others like Azhu’s?
The only 219b I bought from Azhu are the SW45K. The SW35s from Convoy are my first. They are very nice though.
Post #6000!
(at the moment.)
Post #6000!
(at the moment.)
Nice!
You got #5000 as well, if I remember correctly.
Gotta catch 'em all!
Hi Simon,
I see that S12 UV’s product listing now says 2.4A maximum where it used to say 6A before, if I remember correctly. Does it come with a different driver now?
Hello Simon
Could it be possible to list SST20-B (and some other 3535 SMT color LEDs that can be used in place of XPL White LEDs) on your store ?
Thank you!
Hey Simon,
1. It will be available in one week. But the Tc is 5700k instead of 6500k
2. uh ,no plan ,how about M21E? i will add a link of M21E with SFT40 / KW CULPM1.TG in two days
3. It is only suitable for L21B
Simon,
Anyway… TIA
Can you send me some photos? I want to see how you solder SFT70 and MCPCB.
Thank you!
Maybe in one week.
Hi Simon,
In fact, the drivers are the same, but this driver was originally designed for SST40 and not for UV LEDs. Because the vf value of uv led is relatively high, the current of the flashlight will be relatively small.
