Emisar D3AA is available now
Will there be a option to order the new leds(B35AM and SFT-40) when you release the DM11? How much would the shipping costs?
Would it be possible to get SFT40 in the K1?
We do have the option, only that SFT-40 LED is not available yet.
Only that the throw is not that great, I measured about 25kcd throw on high.
It’s the throwiest of all Nichia’s so let’s say it’s a good one
It’s actually right on par with a maxed out 219C, which believe it or not is the previous ‘thrower’ of the 9050+ Nichia’s. Due to the quad die structure, the 219c might eek out a win.
In the end, I think a quad 219c under ledil angie vs b35am under 35mm single optic is going to be an interesting comparison.
D4S vs DM11. These are my estimates, some of which are based on Hank’s previous comments or specs on intl-outdoor
Max W 60 vs 22.5
Max kcd 20 vs 25
Max lm 3000 vs 1550
lm @@ 20W 1600 vs 1500
kcd @@ 20W 11 vs 24
cd/lm 6.7 vs 16
spot angle 18 vs 11
I know this is Blasphemy to mention another Brand, but there is another popular light with a 35mm head, single optic, with slightly frosted center that uses the xhp35 HI, that is only capable of 22,500 cd (with a 5500k emitter mind you).
All of that to say - if the BM35a is as nicely tinted as i am hearing, and the CRI is high, then 25kcd is actually rather good i would say! considering all of the information.
What will the throwiest LED offered be on launch? I was planning on ordering it with the SFT-40, I’m afraid it wont offer much over the KR1 other than aux if it doesn’t have a more impressive emitter than the W2.
Any idea if the flashlight will be released in the coming 2 weeks or not?
I don’t remember where I saw the post on the buck driver, but it’s what made me interested enough to post. I assume it was on BLF, but I occasionally check Reddit for news on Hank’s lights. Anyway, Hank said the DM11 would use the same boost driver that was already used on the XHP35 Hi K1.
Hank do you already know what will be the throwiest option for the DM11? Will it top the KR1?
The throwiest option will be Osram CSLNM1. If it’s driven to peak brightness (4-5A) we should see ~160kcd from it with this optic. The beam should look virtually identical go Acebeam E10 and Thrunite Catapult Mini, it’ll just be a little brighter hopefully.
KR4 tint ramping version is available for now,
https://intl-outdoor.com/
D4V2 tint ramping version will be available as well.
Awesome!
Awesome. Is there a D4v2 or do you only mean D4sv2?
there is now a tint ramping D4V2 (source )
Just got these today! They are great! Thanks Hank!
https://imgur.com/a/Vv9MwBC
Ugh! What LEDS to choose! I’ve settled on 2700K Nichia 219B. But for the other channel. 4000K 351d? Sst20? Or 4500k Nichia 219B?
I think 2700/4500 219b sounds like the right answer. 4000/2700 sst20 is also nice.
Do you think it would be odd to mix emitters? Nichia 219B and sst20 or 351d?
Different beam profiles, I don’t think it’ll blend nicely.
