Amazon Deal Alerts & Discussion Thread
ORHFS 300W Portable Power Station (For Those That Missed The First One)
Although the same unit as the other deal, it’s $209.99 and $100.00 coupon off
for a total of $109.99. Not nearly as good a deal as the other deal from the other
seller.
Moobibear Smart LED Flood Lights, 2 Pack 40W Color Changing Floodlight
$32.00
First impressions: The build quality is not bad. The body is painted/powered coated aluminum. There’s no onboard controls, not even on/off - it’s all controlled by the a coin cell powered remote or ‘Magic Home’ app via Wifi or BLE. The remote is lacking. The app is well designed. it’s responsive and controls individually or all at once. I only tried bluetooth /local mode. it works without an account or wifi access. The CCT Tint and RGB colors are adjustable with a color wheel. Brightness dims to 1 lumen or less. CCT White is significantly brighter than the RGB mode. I doubt it’s 40w equivalent but it’s bright enough. Barely noticeable PMW in lower levels in camera. It could benefit with a diffusor. Overall it’s a pretty good flood light.
I snagged it, just came in. It’s brand new not sure why it was a warehouse deal. I expected the worst to get it loose in a bag or some random cheap light inside the box … but everything was like new didn’t look like it had ever been opened.
Super happy with my first zebralight . Thank you for posting!
With all the reports of smoke and fire it was only barely a good deal at $30. this one looks better to me at the $99 price point
https://amzn.to/3bUmP3L
code: XGZNKJRI
I received mine today. Has volador etched on it. Nice light!!
Great to hear! Mine arrives Friday, but I did receive this one today from the same seller, also with the Volador name printed on it:
$11.24 using code 503NBGAZ
https://www.amazon.com/dp/B08ZSC7JRX?tag=1sale06-20&linkCode=ogi&th=1&psc=1&customid&coupon_code=503NBGAZ
Another cheap meter—- I got one — because that’s what I do —- buy things I don’t need
https://www.myvipon.com/product/8975008-Digital-Multimeter-Tester-Voltage-Meter-USB-amazon-coupons&f=deal&search_tid=618557f95094bb4d2c216cb5
Funny, they have a “worklight” option and one of the images spells military as “”militery”:https://m.media-amazon.com/images/I/71Dmc4k7T5L.*AC_SL1500*.jpg”. They show a 20% coupon, so I take it this other coupon is applied on top? Is that from Vipon?
Sometimes coupons stack and other times they don’t. Plug it in your cart and see.
The coupons indeed stack bring the price to $8.38 for me , However there aren’t any positive reviews for this model . So I am not sure if I should buy .
Received my PowerExtra 300w Power bank today. Arrived in perfect condition and brand new, not some customers return. It had about 54% charge on it,
which seems about right for shipping. I gave it a very careful test before charging it. All inputs/outputs work perfectly. The cigarette lighter input is not regulated,
so when the power bank was at 54% charge, the output power was reading only about 10.52v, which should not be a surprise. The 72w charging brick it came with
is doing a good job recharging it The A/C outlets don’t grab the 3-prong a/c cords as tight as I’d like, but it’s fine. The manual clearly states the output wave is Pure Sine,
so I’m really happy about that. I don’t recall the sales page on Amazon mentioning that. I’m still going to be careful with it for a while yet to make sure it remains
in good working condition, but so far, for $32.00 delivered, it’s a smoking deal (No Pun Intended)
Just a couple of photos for you.
DONLYN Flashlight 5000 High Lumens
$14.99 with Prime and another 30% off applied at checkout which comes to $10.49
https://www.amazon.com/DONLYN-Flashlight-Flashlights-Rechargeable-Resistant/dp/B091KF1TB5/ref=sr_1_197?keywords=rechargeable%2Bflashlight&qid=1636243406&refinements=p_85%3A2470955011&rnid=2470954011&rps=1&sr=8-197&th=1
Interesting, a XHP70.3…
Still for $10.50, I may have to give it a try…
I bought a couple of these shops lights —Last night I decided to try one out in the driveway —- I blinded myself from the reflection off of my white van —- I kept seeing the image of all those LEDs — this thing is stupid bright
https://www.myvipon.com/product/8938770
I’m afraid of it. Also their math about 10000 mah is wrong.
It’s 2x5000mAh, as 2x26650 cells. Just over $10 is terribly inexpensive… which speaks volumes about the flashlight. I wouldn’t trust those 26650 cells, as they must be some sort of $1 cheapie in there. Not going to trust that built-in charger either!
ok.
it is Target.
$8, usually $42.
abundant parts bins.
https://www.target.com/p/rubbermaid-30pc-food-storage-container-set-with-easy-find-lids-forest-green/-/A-80769331?clkid=09e7748aN401f11ecbe5ca973d8c663c2&lnm=79373&afid=dealnews&ref=tgt_adv_xasd0002
“Out of stock.”
“Out of stock.”
“Cannot be shipped to your location.”
“Not available for delivery”
Ie, nuttin’.
What’s their deal?
They’re claiming 10000 mah but 2 series cells don’t double the capacity, only the voltage. Not a big misstatement but I still wouldn’t trust them.
