Hopefully, it should be before November, 15.
The LEDs options are SST-20, XP-L HI, Osram W1/W2, XHP35 HI, SST-40, SFT-40 (not LED stock for now), B35AM R9080 (2700K, 3000K, 3500K, 4000K, 4500K, 5000K, 5700K)
Thanks for the laugh.
Changes are looking great, I gotta get some pogo pins now.
So when will the tint ramping D4v2 be available?
It’s up now, you can also request the same configuration for other D4V2/KR4 materials.
https://intl-outdoor.com/tint-ramping-instant-channel-swiching-led-flashlights.html
Thanks! I ordered it! Wooo!
Btw. Does one control the switch LED with anduril too?
Thanks, the swich LED is controled by UI as well, just like the one in the D4V2 TI.
Any chance you will make a dual channel for the DT8?
Is it possible to go W1 on one channel and LH351D 5000k on the other? Thanks, Hank!
Looking forward to this, thank you.
What kind of driver will the 3V LED’s be using?
John Deez:Has this changed?
- User can choose tint-ramp or tint-toggle. It’s in the hardware-specific config menu (Advanced mode Off 9H).
So it seems this new function is implemented in the new D4V2 and KR4 - right?
From the description: “Anduril 2 firmware, user choose the tint ramping or instant channel switching, Advanced mode Off -> 9H, first menu item: 0C: tint-ramping (smooth) 1C: instant channel switching 4 LEDs can be on at the same time with full power.”
https://intl-outdoor.com/new-emisar-d4v2-with-tint-ramping-and-instant-channel-switching.html
Pavlo:Hank, when will the DM11 be released?
Hopefully, it should be before November, 15. The LEDs options are SST-20, XP-L HI, Osram W1/W2, XHP35 HI, SST-40, SFT-40 (not LED stock for now), B45AM R9080 (2700K, 3000K, 3500K, 4000K, 4500K, 5000K, 5700K)
nice!! I'm much more exited now for this!
also- b45am ?? Oooohh, is that 4 x e21a?? Sorry all of these Nichia models are new to me.
Yes, same die size as E21A but 4 of them on a 3.65x3.65mm package, with less phosphor around the dies so less angle tint shift (more uniform beam), limited to 4A (6V).
Edit : didn’t see the typo, it’s B35AM.
No B35?
Hank Wang: Pavlo:Hank, when will the DM11 be released?
No B35?
B35 is the whole last 2 lines of that post
trakcon: Hank Wang: Pavlo:Hank, when will the DM11 be released?
No B35?
Above, i asked about this and The Freeman responded, it's a typo. I thought the B45AM was another, different Nichia LED i had not heard about. Just a typo from Hank apparently. :))
A DT8 with 2000k + 5000k e21 tint ramping model would be so cool!
John Deez:I like my KR4 e21a. I wish it had a lower low, and slower ramping, especially at lower lumens. I struggle to get a good lower setting for reading because it ramps too fast. Has this changed?
Did you set your lowest ramp to 1? It’s a default of 3 out of the box, and needs to be set to 1 to enable the moon light level. I don’t think it’s possible to go lower than the light level of 1 on this driver. Although I actually find the level 1 setting to be very nice on the e21a LEDs.
Are you talking about the original KR4 driver or Anduril 2?
TitaniumDust: John Deez:I like my KR4 e21a. I wish it had a lower low, and slower ramping, especially at lower lumens. I struggle to get a good lower setting for reading because it ramps too fast. Has this changed?
The driver hardware is the same and the default ramp settings are the same between the A1/A2 versions. Newer A2 versions have dynamic PWM to slow down the ramp speed at lower levels but you still need to manually set the ramp floor to level 1.
What are the differences of these 2?
anduril.2021-11-03.emisar-d4sv2-tintramp.hex
anduril.2021-11-03.emisar-d4sv2-tintramp-fet.hex
One has FET drive enabled for channel 1. It’s for K9.3, where there are enough emitters on channel 1 that FET drive won’t fry them.
The other one doesn’t have FET drive enabled on channel 1, and it’s for the 2 channel variants of D4V2, D4SV2, and KR4.
Edit: I am wrong. TK has weighed in below.
