FREEME ✌ ASTROLUX WP3 LEP 562lm 2952m 21700 Flashlight Group Buy
I’m pretty sure it wouldn’t fit. Although I might get one anyway to try, and use it for my FT03 if it doesn’t work.
FT03 = length - 170mm, head diameter - 69.5mm
WP3 = length - 184mm, head diameter - 59.5mm
Holster has room for extra 14mm but it will be tight fit though.
ASTROLUX WP2 185mm
I’ll give it a try, thanks Freeme
Interested in code, too!
Just received mine and it is a crazy thrower. Just curious if anyone has tried the 26650 battery in it yet. As you know it comes with a 21700 battery and various reviews indicate that a 26650 battery will work as well. However the owner’s manual makes no mention of the 26650 battery only the 21700.
Used a 26700 and it worked fine as far as I can tell; not that I use the light much as I don’t want to frighten the good citizens of the neighborhood.
Any recomended 26650 battery?
Thanks in advance
VapCell INR 26650 5500mah 20A (2021)
https://www.aliexpress.com/item/1005002424304589.html or similar 26650 with 15A?
Hi Freeme. Please send code. Thanks.
You got mail!
Ordered. Thanks for the code freeme! :beer:
This is going to be my first LEP and I simply can not wait for it to arrive!
My current longest throwing torch is the Convoy L21a CULPM1.TG.
You won’t be disappointed. It still makes me laugh every time I turn it on!
Thanks TMaxxJJ.
I’ve actually got a real use case for it. I really enjoy stargazing with friends. Until now I used a laser to pint out stars, but lasers have two problems for me.
1. They really are very unsafe to use without proper eye protection.
2. I usually have to make sure that there are no aircraft flying in the same direction as where I point the laser.
Hopefully an LEP will solve both problems.
Don’t get me wrong, I bought it mostly for fun. However, it will also serve a real purpose.
LEP is definitely in a league of its own.
interested
Interested
order placed, got Astrolux Upgraded A02 SST20 as a gift
Any recommendation for diffuser that can be open? I heard that the diffuser for the Weltool W4 will fit it with an o'ring, but is there something better for it, that will just fit?
How did you get the free gift?
I’ll take a coupon Sir Freeme
Hi,
is this still active? I think I deserved a gift and WP3 is on the top of my wishlist :slight_smile:
