silver Oxidation
EL1IFJY1VNKS
Got an HS05 with the $3 off code, so thanks.
12% presale of SP33S CODE--PRESP33S ,use XHP70.2 6000-6500K LED 5000LM output, compatible with 26650/21700 battery, Type C charging and reverse Charging Max 5V 3A
50 pieces of first batch in all
Link of SP33S: https://www.aliexpress.com/item/1005003438724316.html?spm=5261.ProductManageOnline.0.0.31114edfStG4nZ
Sofirn New Model Presale, shipping in 5-7 Days, first small batch of HS10 16340 Angle Light, work as a headlamp, 1100lm by LH351D 90CRI
LEDs. Enjoy coupons ordering on 11.11 deal day! Thank you.
Thanks Jackie, code worked, just ordered two more SC31PROs.
Hi Jackie, is there a code for the new hs10 headlamp?
Thank you bro
yes, here update :Q21DTP3E1BLK
Thanx for the code, bought one! :+1:
Would be nice if the HS10 had an 18350 body option. Just a nominal size difference yet big punch up in mAh gain.
I’m curious about the c8l is it 21700 like the g and f?
Black Friday Deal start from 25th to 29th, more codes will update soon
You are the best
$2 unlimited code 30 pieces --1QMYAPO4H7LV
$3 unlimitd code 30 pieces---9ULIBJ6NNU3N
valid time from 25th--29th, during black friday deal
Thanks. I took advantage of ...
On Deal Now, thanks for all support
$3 unlimitd code update---9ULIBJ6NNU3N
hi ! I’d like to buy HS40, but only if the head can work on SP40 bodies (19650 & 18350) ?
thank you
