FREEME ✌ LUMINTOP GT Nano Pro Flashlight Group Buy - ALIVE Today!
Interested
Interested
No problem!
interested!
I can't resist any longer! Please add me to the interest list! I have a slight preference for LH351D emitters but, SST-20's or similar high CRI are all good assuming they are "Natural White/5000K~5700K".
Interesting light but I’m not in. :slight_smile:
Hi Freeme,
I seem to remember something about the aluminum black GT Nano with the extension tube and a possible issue with damaging the LED when running in turbo too long. Do you know if the GT Nano 3 will have the same issue?
That must be with a 10440, right?
That happened in the (early) batch(es) that had a thinner PCB.
The later/current batches have a thicker DTP MCPCB (1.8mm), which is much better handling higher currents.
The GT Nano also had that issue because of the led used (osram) which is more sensitive to higher Amps. I am sure that the GT Nano 3 won’t have that issue, unless a paper thin PCB is used…
I don't know about Sweden but, my normal sources in the USA have 10180 batteries for ~$3 each. With 50~70mah, I tend to think these are a one-trick pony. The AAA size 10440 to me is a lot more attractive. Sure it is a bit longer so, maybe not as impressive to non-flashaholics and may be a bit more troublesome on a keychain but, I still find the AAA size about as small as I want to go.
Interested.
Interested
Yes, my ceiling bounce shows a peak up to 1050 lumen with a new vapcell 10440 !
Interested
Interested
Interested
List updated.
I am using Vapcell INR10440.
Interested!
Interested
