FREEME ✌ MATEMINCO MT70 MINI SFN55.2 6800lm 26500/21700 Flashlight Group Buy - Shipped
All Right,
I see the Astrolux FT03 tubes on Banggood and the blue is in stock, estimated delivery by end of this month. The link:
https://m.banggood.com/26800-Battery-Tube-For-Astrolux-FT03-FT03S-LED-Flashlight,DIY-Extended-Body-Tube-For-Large-Capacity-Longer-Runtime-26800-Battery-p-1865528.html?rmmds=detail-middle-buytogether-auto&cur_warehouse=CN&act_poa=POA8712188
The handle knurling pattern on these tubes is identical between the FT03s and MT70 mini. It seems the proper way.
The MT04 tubes at Neal's have a radically different pattern of handle knurling yet appear thread compatible. Tom, are you certain these WONT WORK, other than the aesthetics?
I think I'll take a chance on the BG FT03s tube...
Thanks again!
Many Thanks Tom for making it crystal clear, and for dispatching an email to Neal.
Best Regards my friend
I can't be certain of anything, including if I put on matching sox this morning...
These models are insane - I don't have an MT04 but it appears the MT01 is the same size and style, so I'd bet on it, plus texas shooter is pretty good with this stuff as well - I'd trust him more than myself...
I have both, they are not compatible. Neither the head or tail cap on either.
The FT03 26800 Battery Tube fits the Mateminco MT70 MINI. It also fits the copper & brass versions of the FT03.
Banggood link
Use Fin17’s code to bring it down to $11: FIN5528
Has anybody found another source for the 26800s,preferably in Europe? Shipping cost is prohibitive.
lOrdered from Neal 11/04, received yesterday (11/18); good compared to my AliExpress orders recently, and the tracking info was detailed and accurate.
Thanks again Freeme.
Thanks FlashPilot and freeme! Ordered the MT70 mini in green from Neal, and the 26800 tube in green from BG.
Have received my MT70 Mini today, enjoyed the nice donuthole free beam, but when testing turbo i think:
Well, where is it? This is never ever Turbo.
Made an factory reset, cleaned the Tube and Contacts and no change.
Ok, compare turbo with an ceiling bounce to another light:
FT03 XHP50.2 5700K 540lux
MT70 SFN55.2 370lux
Used the same QB6800 Battery in both lights, that ist really, really disappointing… :cry:
Any idea what ist wrong with the MT70?
Is the battery mostly charged? If so then ramp the light to high. At high double tap to compare turbo increase. The lower the cells charge the less turbo stands out.
Ok, ramping high and than double click i got 640lux in the ceiling bounce. :+1:
Power of, double click -> 370lux
Weird behavior…
FT03 is NasilM where ramps to turbo. Anduril doesn't by default ramp to turbo. So it says NarsilM in the OP, but maybe it's not?
Ah, the fog is clearing… :sunglasses:
First post states NarsilM, same as the FT03. Never thougt it could be wrong.
I have pulled the Matemico manual out of the box (which is for an MT90 mini with SBT90.2) and it is for Anduril.
double click + double click go to turbo…
Ok, going to RTFM for changing this…*g
I think their all Anduril. Got a question, how are you liking the 26800 cell and where did you find yours?
This behavior means that the light probably has Anduril 2.
Same here. The box had manual for MT90 mini with SBT90.2. I showed the light to a friend, he liked it a lot, ordered one, and same thing. His light came with manual for MT90 mini with SBT90.2.
RTRM. read the right manual.
Well, anyway, the MT70 Mini SFN 55.2 is one of my favorite lights. A very nice combination of beam power performance and beam profile for its size and cost.
So far, I haven’t had a Mateminco/Astrolux flashlight that uses Anduril 2 yet (the only exception for “Astrolux” brand flashlight with Anduril 2 would be the EC06, but this appears to be a Sofirn-manufactured light instead of Mateminco).
Most Astrolux/Mateminco flashlights that use Anduril (based on my test) have the factory reset function (hold button while tightening the battery tube), but do not have the 15-clicks version check function, indicating a relatively older Anduril version. (these include: MF01-Mini, MF01S, FT03S SBT90.2, HL01, EA02 models)
The Astrolux/Mateminco models that use Anduril, and with version check would be these: EA01, EA01S, FT02S, which has Anduril 1, version 2019-12-05 (this firmware version is not listed in Toykeeper’s Anduril repository, so it could be a self-compiled version by Mateminco).
Got them from Aloft Hobbys. The lights (EA01S, FT02 and FT03) lay definitve better in Hand with the longer Tube.
More capacity is always good…:slight_smile:
How many need MATEMINCO 26800 tube?
Hi. If code still available may I have one?
Thanks.
