I think their all Anduril. Got a question, how are you liking the 26800 cell and where did you find yours?
This behavior means that the light probably has Anduril 2.
Same here. The box had manual for MT90 mini with SBT90.2. I showed the light to a friend, he liked it a lot, ordered one, and same thing. His light came with manual for MT90 mini with SBT90.2.
RTRM. read the right manual.
Well, anyway, the MT70 Mini SFN 55.2 is one of my favorite lights. A very nice combination of beam power performance and beam profile for its size and cost.
So far, I haven’t had a Mateminco/Astrolux flashlight that uses Anduril 2 yet (the only exception for “Astrolux” brand flashlight with Anduril 2 would be the EC06, but this appears to be a Sofirn-manufactured light instead of Mateminco).
Most Astrolux/Mateminco flashlights that use Anduril (based on my test) have the factory reset function (hold button while tightening the battery tube), but do not have the 15-clicks version check function, indicating a relatively older Anduril version. (these include: MF01-Mini, MF01S, FT03S SBT90.2, HL01, EA02 models)
The Astrolux/Mateminco models that use Anduril, and with version check would be these: EA01, EA01S, FT02S, which has Anduril 1, version 2019-12-05 (this firmware version is not listed in Toykeeper’s Anduril repository, so it could be a self-compiled version by Mateminco).
Got them from Aloft Hobbys. The lights (EA01S, FT02 and FT03) lay definitve better in Hand with the longer Tube.
More capacity is always good…
How many need MATEMINCO 26800 tube?
Hi. If code still available may I have one?
Thanks.
Code and link on original post: https://budgetlightforum.com/t/-/67652
After reading some threads, is it possible that the setting “2C to turbo from off” must be set before compiling the firmware?
Not sure where that comes from Anduril or Anduril 2? I don't see anything like "2C to turbo from off" in Anduril 2.
2C from OFF goes to the top of ramp. If you configure top of ramp to be turbo, then a 2C from OFF will go to turbo. That's the only way I know of to do that.
In my Anduril 2 builds, I'll set up the behavior to be like Anduril 1 - if the light is ON, a 2C goes to turbo, or from OFF, do a 1C then a 2C to get to turbo. This will work with the default top of ramp.
MATEMINCO MT70 MINI + 26800 tube + 26800 battery bundle and available for us in northern Europe with a fair shipping fee?
Any news about this light with 26800 tube and battery for Europe?
I ordered and received the 26800 tube from BG - no light to go with it though from Neal. Dunno why BG's shipping has been so good lately.
Banggood has been using airmail lately then straight to USPS instead of a slower intermediate. I’ve gotten quick mail lately too, a few dollars more than the free shipping of old.
I got in the FT03 MT70 Mini! Nice! On a Lishen LR2170LA @4.20V, 19.9 amps at the tail, 6200 lumens at start, 211 kcd. I can't get it to run 30 secs without tripping temp reg.
I'm gonna add spring bypasses and check the LED wiring and try a T42 cell.
So I got another FT03 w/XHP50.2 3V and just added spring bypasses. Measured 19.7 amps, 5560 lumens at start, 189 kcd.
So for about the same amps, the SFN55.2 is about 10% brighter, throws better and has a much better tint in the beam. The XHP50.2 is supposedly 6000K with a blue flood, yellow corona where the SFN55.2 is white through-out. No contest here.
Wow putting 20A into a XHP 50.2…
Before/After spring bypasses, and removing the 2nd inside spring (amps measured with tailcap off):
MT70 Mini w/SFN55.2 stock on a 26800 at 4.20V: 19 amps, 5390 at start
MT70 Mini w/SFN55.2 w/22 AWG bypasses on a 26800 at 4.20V: 20.7 amps, 6300 at start, 217 kcd (2 sec pause)
MT70 Mini w/SFN55.2 w/22 AWG bypasses on a T42 at 4.20V: 22.5 amps, 6670 lumens at start, 220 kcd (2 sec pause)
On Taobao, Mateminco now sells a new SFH55.2 version of the MT35 Mini as well. I’m going to pick that up on Double 12.
Does your light have Anduril 1 or 2 Tom?
It's Anduril 1 - no version on 15 clicks, exiting lockout via 4 clicks, the main LED is OFF.
Just upgraded the LED wires to 18 AWG, from 20 AWG, swapped the OP reflector with an SMO, and had to add a copper shim (1" 18 AWG) under the MCPCB to keep the SMO from rattling (very slightly shorter). The beam looks great w/SMO and got a bump in throw.
On a 26800 at 4.20V, now I'm measuring 21.7 amps, 6210 lumens at start, and 254 kcd throw (2 sec pause).
So lumens went down a little (6300 -> 6210) but throw went up (217 -> 254 kcd).
This one might need a group buy with 26800. It’s a significant increase in output. Would also like to see a group buy with the Mateminco MT01, 26800 battery, with the SFN55.2 or SFH55 LED.
Freeme can you pull this off?
