The sfs80 is 263% the size of the w2 and 132% that of the sft40. I think some might be missing the point of how large this emitter is and that north of 3300 lumens would be needed to match the sft40 at max output and nearly 4200lm to match a w2 in intensity. Short of some voodoo magic - or a terribly nonhomogeneous brightness across the die surface - there is no way it competes in the throw realm with these emitters at max output. I could believe /expect that in the 3-5A range though it will put out more lemons than the sft by a meaningful margin.
That is pretty! Is that a photo from Hank, or do you have the prototype in your possession? If it’s in your posession, what emitter is it? How’s the knurling?
It’s in my posession. This light has a B35AM in 5000K. The knurling is definitely pretty aggressive, I think it might be a bit too abrasive for pocket carry. There was a pocket clip included with the light, it’s a new design.
Hank says this is 99% identical to the production verison, I don’t know what has or hasn’t changed. This light actually has a Noctigon branded tailcap.
Hank, do you have any comparison pictures of the beams from the available B35AM emitters? I’m trying to decide which B35AM to order, but I can’t find much info on them. Are they all 90+ CRI?
Pretty neutral, just a bit on the green side, especially in the spill. Overall it has a very natual, very white look, compared to something like an SST20, but not as pretty as 219b. I like it.
It is not deep carry, and is a clip-on design like d4v2. It’s also black
