LuxWad - agree with everyone: your videos are fantastic and you now have a new subscriber, the informative yet relaxed (and honest) reviews are spot on
I have around 20pcs of B35AM and AR and they can sustain 1000lm without a sweat. Better find one and try so you’ll see how underpowered looks this initail video…
Hank's rating is 1400 lumens with the B35AM. Video shows 3.6 amps from a boost driver for a 6V LED, looks like 1650 at start, so maybe ~1500 at 30 secs. The light is 120 mm long, 40 mm head - nothing at all very big, think of it as a BLF/Eagle X6 but little shorter, or an Astrolux EC01 but slightly larger head diameter.
My immediate question is why limited to 3.6 A? Can the driver take 4 amps?
In my builds B35Am at 6V/4A turns a lot rosier than realy is so it’s on a max driving limit. Sosetting it on 3.6A is very good idea. Only stepdown is a minus
Cool! Sounds like the R&D has already been done on these LED's. Not clear from Hank's listing, but looks like the output binning varies based on the tint - lower tint, lower output. E700, E800, E900, E1200 shown in the store listing https://www.eurekatronix.com/product-page/nichia-b35ax?
So the 3500K is E700, 4000K is E800, 5000K is E900, etc.
Page 4 has the lumens outputs at 1.4 amps. Hhmm, might have to re-consider 3500K. 4000K jumps up to the next output bin, roughly 200 lumens more I'm guessing for 3.6 amps.
Sounds good to me. I typically use lights like this for walking the trails at night, and I usually stick between 5-20 lumens. Just enough to see down the trail without ruining my night vision.
My current go-to is a D80v2 with 219b and a 2A max regulated driver. The B35AM 3500K will probably more than double the max output of my D80v2.
Kaidomain. I wouldn’t exactly call their $24 XHP35 C8 a serious competitor to the DM11 though.
I think a better question is what does compete with the DM11/B35A? Perhaps the Acebeam E70/FC40? That’s the same price. The Zebralight SC700d? That’s considerably more expensive.
“the light was calibrated but I did not adjust the thermal limit” - direct quote from the video
He did calibrate the temperature sensor. He just didn’t change the max temperature it can reach before stepping down. Those are two different settings.
I think this is the most relevant way to do a runtime test, since 45C is both the stock thermal setting, and a reasonable temperature to still be able to hold onto the light without gloves.
I know what he said but since FW3A release there was a strong recomendation to set 60deg max temp. If you run it at this low value then why going for this not so pocket friendly item. Convoy S21A with 6V/3A driver and B35Am fits better to your need and sleeps into the pocket real nice.
So i hope Wad will adjust those settings to more apropriate values for this big “mid range” thrower and so shy 45
