If bugs are the only reason, amber is a much better choice than red since bugs that are attracted to like are attracted to the blue/violet/UV end of the spectrum.
As far as red and “night vision”, well that’s a whole ’nother debate/can of worms I’d rather not have opened in this thread lol.
It is too short to be the same. Also if you look at the 4th image on AE there appears to be a usb port and the switch button located in the upper surface. The description mentions 21700 battery. I believe there might be one cell placedflat, or horizontal in a very short base section that a modified LT1 head is fastened to
Very interesting
Interesting, but its not the LT1M (Mini) its likely a lower run-time/dimmer, single-cell variation of the full size LT1 they decided to build on their own, its looks different other than the head “shape” but using a single cell in a center tube. The LT1M is to be much smaller, slimmer, more compact (better suited for backpackers, canoeists, etc.) using the same single 21700 cell, but able to fit in a pocket and not much larger than the IF25 body its to be based from.
