What about just using a red filter? Fashion a canted filter to match the slope of the LT1 translucent lens, then put on the inside…
Interested!
If bugs are the only reason, amber is a much better choice than red since bugs that are attracted to like are attracted to the blue/violet/UV end of the spectrum.
As far as red and “night vision”, well that’s a whole ’nother debate/can of worms I’d rather not have opened in this thread lol.
Additions to the interest list since post number 1271
Post# / Added / User Name
1287 / 11/24/2021 / viper1138
Saw this in aliexpress via Lumeniac’s post. Is this different from the LT1 Mini? https://www.aliexpress.com/item/1005003601508703.html?spm=a2g0o.store_pc_allProduct.8148356.3.2ced3bb4oBjVy8
Good question.
Yes, the design is different!
Yeah the design was obvious but the specs does say 1x21700 though I can’t figure out where the 21700 goes. Oh well more lantern choices I guess.
It is too short to be the same. Also if you look at the 4th image on AE there appears to be a usb port and the switch button located in the upper surface. The description mentions 21700 battery. I believe there might be one cell placedflat, or horizontal in a very short base section that a modified LT1 head is fastened to
Very interesting
Saw this in aliexpress via Lumeniac’s post. Is this different from the LT1 Mini? 37.49€ 50% OFF|Sofirn LT1S USB C 21700 Wiederaufladbare Camping Licht Leistungsstarke Taschenlampe Tragbare Notfall Laterne 2700K 6500K mit Reverse lade|LED-Taschenlampen| - AliExpress
Looks like a LT1 without the body.
Reminds me of the Zanflare T1 and similar lanterns. Battery and internals are all inside in the center. Very interesting.
Interesting, but its not the LT1M (Mini) its likely a lower run-time/dimmer, single-cell variation of the full size LT1 they decided to build on their own, its looks different other than the head “shape” but using a single cell in a center tube. The LT1M is to be much smaller, slimmer, more compact (better suited for backpackers, canoeists, etc.) using the same single 21700 cell, but able to fit in a pocket and not much larger than the IF25 body its to be based from.
Interested in 1, please.
What happened to prototypes, will there be pictures for Christmas presents?
I sent Barry a PM last night asking him about the status of the prototypes.
Interested in 2
We are waiting for info on the prototypes to be sent to us to be tested, to work forward to a production model!
Addition to the interest list since post number 1287:
1288 / 12/10/2021 / cf3712
Thank you very much.
Very interesting
Probably just like the Fenix lantern in reverse with vertical cells, inserting battery from the bottom instead. The Fenix uses 3 18650’s inserted from the top.
