The lowest level on this light is about 0.46 lumens, which is lower than any other boost-driver light I have used. Interestingly, the moonlight ājump-startā is much too strong on this light and causes a bright flash, even at the lowest level of 1/50. However my light is not using the latest firmware (2021-10-04) ā¦I had to order another USBasp and canāt reflash right now, so perhaps things have changed slightly. Itās also very unstable on the lowest level, with a strong flicker that can even be seen in the video.
The max output at startup (1,640) is an average of multiple tests, the highest I recorded was 1,683 (immediately at startup). @ 30 seconds it is 1,610 lumens. Those numbers are not guaranteed to be super accurate though.
Also yes, the light was indeed calibrated, but the test was ran at the default 45C. I think the default temperature is the most meaningful, as it still gets pretty hot in the hand, but Iāll do tests at higher max temps as well. Bear in mind too the runtime test is literally done in a bookshelf @ 21C, so thermals are not best-case scenario.
And yeahā¦ this light should have had a lanyard hole
Funny though as I think most people still prioritize quantity over quality. Maybe this is subjective, but at one point I think 20% more lumens is a minor increase compared to the jump you get in clarity going from CRI 70 to 90+. There are a lot of bad tinted high CRI options out there, but enough good ones that personally donāt see the need to ever go back to a low CRI light.
On mine, I measured ~0.56 lm to ~1300 lm with a 50E cell. Moon was stable, but turbo wasnāt as bright as I expected. However, I havenāt measured with a higher-amp cell. It could just be a weak battery.
I see the moon pre-flash here too, and I wasnāt able to get rid of it. I think itās a hardware quirk, because it shows up even with jump-start at level 1 (which is default, and effectively means no jump start at all). I should still double-check though, to make sure it still happens even when jump-start isnāt compiled in. As far as I can tell though, simply turning on the boost circuit, without even sending any PWM to the control pin, causes a brief flash. Itās sending a flat zero for the brightness level, and it still flashes.
For thermal tests, what Iāve found works well (simulates real-world use, approximately) is to rest the light pointed downward on a wire shelf, with a fan on ālowā blowing gently toward it from about 1 meter away. I place a phone under it to log data, and I adjust the position so turbo mode reads roughly 50% to 90% on the lightās sensor. Iām using an old Nexus 4, and its sensor goes from 0 to 10,000, so I typically try to make turbo read roughly 8,000. This gives good resolution without clipping. Hooray for analog gain staging!
For narrow lights, I place a spare lens on the wire shelf, and put the light on the glass. Thatās only if the light is small enough to fall between the shelf wires though.
The startup current overshoot is something that I have in all the boost drivers Iāve made, but itās only really problematic with the MP3431 based ones, Loneoceansā boost driver had this, Mike Cās too, he used a small FET to pull down the Op-Amp inverting input for a short duration during startup to solve this, when using a dual sense resistor topology for very low moonlight like I do this can be mitigated by waiting for a couple of ms before turning on the high power range FET.
Both of these solutions donāt have support in Anduril though, and it would need a hardware revisionā¦ depends how problematic it is in the case of the DM11, how bright is this flash ?
Edit : I missed Luxwad comment, so ābrightā it is.
For floody purposes, absolutely. For a thrower to lighten up something 100-200m away, Iām not sure. FF E07x pro, I would love some high cri, if it was 6000 lumen plus, but that generates heat. Ahrgh, itās all a circle jerk with compromises!
Hank, what currents are you using for the newer e21a tint ramping drivers? Are you still using only 1.25A/led by default as with the original 5A driver?
Can we chose to use 1.5A/led - 1.6A/led? What about with the upcoming DT8? Thank you.
Hank, How are you guys holding up? I guess that you met some pressure with the release of the tint ramping lights, plus the DM11. You must be working your asses of 24/7! Hope you get some rest from time to time!
Hi Hank, Iām asking out of curiosityā¦ why donāt sell products on Taobao? I know you have a store that you can take Alipay but you donāt list any products. It seems like you have a fan base in China as well but they might have trouble figuring out how to order.
Iād be happy to recommend your lights to Chinese people I know but itās too complicated for most.
Thatās understandable - Taobao customers typically expect instant customer service from 8am to 10pm. It sounds like you need to expand and hire more workers to take off some of the time burden. å ę²¹ļ¼
Hi Hank, is there any possibility of an alternative body tube for DM11? The current DM11 tube is too aggressive and small. The pocket clip is unusable too. I would love to be able to buy a 26800 tube just like D4SV2ās. Itās perfect.
I am also curious, why did you choose to make D4SV2, K1, and DM11 all have slightly different threads despite being almost exactly the same diameter where the body tube connects to the head? Being able to swap a D4SV2 or K1 body onto my DM11 would solve all of my problems with it. Please consider using a standard thread pattern on new models with similar connection sizes.
I ordered Nov 25 and the price has not changed for the version I ordered- green with green switch led, and 3500K, B35AM LED. Still $74.65
I never saw any other options listed when I ordered. Only the body color, switch color, and emitter.
