I ordered the latest Anduril 2.0 version from the AX store, which has the fifth-generation (IIRC) “BLT-LT1-A2” driver, green/blue switch LEDs, and power bank function (the last of which I have yet to test). The package label also identifies it as “Q8LT1” which someone suggested also indicates the latest version.
After being taken out of locked mode, it turns on, which according to a simple tip, indicates it’s running Anduril 2,
However, unlike my SC31Pro, which clearly blinks out the expected version (2020-03-18) during a version check, I get an odd result from the LT1, seemingly with extra digits:
2-0-2-0-0-1-2-5-0-6-2-1
How should that be interpreted?
I’ve performed the thermal calibration with my other lights, but have read that since the LT1’s remote LEDs aren’t close enough to the sensor to get a usable reading, the thermal functions are disabled, or at least, rendered moot. Is that not the case? Should LT1 owners perform the thermal calibration procedure in any case?
Thanks for providing a clear, and logical explanation, which is often not returned in these, and other discussions.
I suspected the last few digits might be a variant, or sub-version of some kind. Is that an Anduril 2 thing?
More puzzling was the 2020/2021 discrepancy. I could have sworn I repeatedly saw an extra zero before the one, but after further review, I now see it correctly. Maybe I need to lay off the sauce…
Further observations — I don’t intend to rely on the power bank feature, but tested it anyway to verify that it works. It does, at least for a short observed period. I assume that the amber “sufficient charge” indicator that remains lit for a brief period after the cable is detached applies to both when the LT1 acts as a source, as well as the sink, and being charged itself. The wording in the manual is vague, and doesn’t note that.
Charging the LT1 via an A-to-C cable results in the flashing blue indicator, as expected. However, charging it via a C-to-C cable results in a flashing amber, not blue, indicator. Is that the expected behavior?
I like to have digital equivalents of documentation, and since I haven’t been able to find the manual for the A2 version, aside from a photograph of it, I’ve scanned the printed manual myself (despite whatever E&O it may have).
This makes zero sense. Did Sofirn make another version of the mcpcb? :person_facepalming: Can you take a clearer picture so we can read what is on the mcpcb?
It looks like there are few versions of Sofirn A4 boards now. The questions about the flashing key have come up already.
I am adding one more. Those 8 pads, 1 through 8, are probably corresponding to the pins, 1 though 8, on the chip. We need to confirm it. My question is more basic. Is it just me that the alignment of those pads looks like curved, not straight? If it is indeed curved, it looks like straight enough. So, the pcb for the key from Oshpark probably works, assuming the spacing is OK. The pins just need to be wired correctly.
By the way, I can see it is the “A4” board in the picture.
It does have a powerbank function, didn't get it to work yesterday with the same cable for some reason. The version is 202108290621. Here's a better lit picture:
odd… i haven’t seen this version of the MCPCB before. I don’t know why Sofirn is changing the boards in this manner. Maybe Barry can answer these questions?
Pick a colour, any colour and someone somewhere will not like it. Just human nature. I myself I’m used to red, yellow/orange and green from traffic lights and traffic signs. My mind associate those colours to certain pattern of behavior.
Both of mine are a steady green in normal use with blue and orange when used as a power bank or charging. I lower the intensity of the LED button because I prefer it that way. I had it off for a while and found that I miss having the green indicator light. I use one almost everyday on the jobsite and always 1/4 turn to manually unlock before putting it back into its storage bag. It’s good to know at a glance that it is ready to go and do not require 1/4 turn to engage the batteries and vice versa when I’m ready to put it away.
Thanks for the info. So it looks like the BLF-LT1-A4 has an updated Anduril version
For reference: the BLF-LT1-A2 - Anduril 2 version check shows 2021-01-25 model 621, so this A4 has a more updated firmware version (January 2021 vs August 2021). Not sure if there are any significant differences though between those 2 versions.
However, I wonder if any chips inside the driver board could also have changed…
