We need 9 XM-L heads now. Then we can stuff 3 x DRY drivers inside and use 3 x 26650 IMRs or King kongs. Hehe.... In High it should do approx 5000 lumens OTF? (IIRC it is about 1700L OTF in High with fresh cells). Turbo, if the batteries can take it then 7500L OTF is doable.
4A x 12.6V = 50.4 W pulled from cells
50.4W x .80efficiency(typ) = 40.32W into LED array
40.32W / 7LED = 5.76W/LED
5.76W / 3.4Vf = 1.69A per XML (assuming 3.4Vf)
So on paper it should be more lumens than the TR-J18/J12, and the bigger reflectors will project a tighter beam. It draws almost double the power of the TR-J12.
After the accident, realised that life is short. need to get more lights.
2.3-2.4A seems to be near the original triple XM-L SR3800….but that’s like 2.55A 2 cells but for 3 XM-L. This is with 1 extra XM-L for slightly better efficiency. I think this one could be like ~ 3200 lumens OTF. Cool!
Oh right… my calcs above neglected Vload<Vno-load for each cell.
Under load cell-V drops and the calculation looks like this with estimated Vload=3.5V (I normally use Vnom = 3.6V for calcs like this)
4A x 10.5 = 42 W pulled from cells
42 x .80efficiency(typ) = 33.6W into LED array
33.6W / 7LED = 4.8W/LED
4.8W / 3.4Vf = 1.41A per XML (assuming 3.4Vf)
Slightly less than the previous calculation at 4.2Vbatt
Anyway the Solarstorm is not driven that high, at 2700L OTF as the 2A driver is not “stable”. So not sure which one to aim for. But i’ll surely use protected cells here which i’d test conscientiously!
To give an idea on the heat levels, the Trustfire TR-3T6 triple XM-L with 1300L OTF is driven to such levels. This light has 7 T6 but quite a bit bigger. 1.12kg is no joke with most of it at the head. TK70 is 769g. But i suspect that 1.12kg is in error.
