Amazon Deal Alerts & Discussion Thread
I dunno... IPStank cell looks like it might be proprietary, with a flat middle button contact and a surrounding ring contact. Browsing the images of both lights shows the same cell design in each.
As much as my inner flashaholic wants one for each vehicle, think I'll pass unless standard 18650 cell design is confirmed. Thanks for posting.
slmjim
That IPStank flashlight is pretty ugly, but beauty is in the eye of the beholder.
That’s what I say after I eat asparagus.
Waiting for the Skank models to come out .
They're out!
NSFW:
https://abload.de/img/skank_models_4qjlh.jpg
Where’s the code for those —- :smiley: :smiley:
How does one justify that collection to SWMBO? Inquiring minds want to know...
slmjim
Samyoung Rechargeable Spotlight with 6 Lights Modes, 10000 Lumen Super Bright LED Flashlight, IP65 Waterproof Handheld Spotlight 10000mAh
$29.99 with Prime and an extra savings 50% off promo code 83JXRBHK
$9.14 with no code/coupon.
For $15 I may have to bite on this
I bought a similar one on the same type of deal some months ago. I like it a lot.
I used the COB work light recently and it was pretty bright . Not the worst 15 bucks i ever spent
This Shower Head works great — I usually have to drill out the water saver crap — this one was wide open
https://www.myvipon.com/product/9029764
interesting… I’ve just replaced 2 shower heads specifically for their low flow. Still more flow than I’d like.
I’d also ordered a Stank and the description says “Supporting standard 18650 rechargeable battery”. I would not have ordered if it wasn’t.
$10.50 with code 35GOYBRK
https://www.amazon.com/dp/B09MT2XF88?tag=1sale06-20&linkCode=ogi&th=1&psc=1&customid&coupon_code=35GOYBRK
Mmmm... I saw that too. Might be "Chinese standard', not unlike 'Chinese lumens'; they can write anything they want, and Muggles won't know the difference anyway.
Image below is from the grey $7.99 light. The appearance of the apparent contact design on cell's end is why I became suspicious.
The image below is from the black $16.64 light on the same page. Same light, just different anodizing. Much more damning. The end cap looks to have a center spring contact as well as a raised contact ring that matches the ring around the center button of the cell. The contact assembly on the cell appears to be secured under the wrap.
To me, a proprietary cell of unknown origin for a light from an unknown manufacturer that requires said proprietary cell is a death knell for that product; glaring, planned obsolescence. Hope I'm wrong, because this light would be a very good addition to a vehicle for emergency use. But, I've become sensitive to deceptive marketing when claimed descriptions don't match images of the product.
BLF members - please, when your IPStank lights are received, let us know if a standard 18650 cell is truly compatible.
slmjim
Well that Stinks!!!
I got mine - is it safe to try a regular 18650 ? Or would I be making my very own IED
I have the same question. I just received mine too. The center circle on the battery, on both ends is positive and the outer area is negative. So the stock battery
can be placed in the light either way and work fine. But what happens if a NORMAL 18650 is inserted???
I like the fact the window breaker end seconds as a cigarette lighter insert to enable you to recharge the flashlight and the other end allows you
to use it as a power bank.
I’ve seen batteries like tis before— I’m thinking it enables the charging circuit to work without the light being on
