NEW high current 60V 24A 1440W power supply RD6024 is released now
Pulled the trigger on one yesterday. I have been waiting on this 24 amp model for awhile.
I have two of the older DPS models which have been great but I really wanted this newer better display model.
The on and off membrane switch on the DPS model was a little hard to push, sometimes the whole power supply would move just trying to activate the on switch. Hoping this one is much easier.
thank you , hope you like that
I did the same, I also have a DPS model (5020) and yeah the interface is really subpar.
24A is nice although I would have preferred 30A.
I’m wondering if this model has reverse polarity protection — I’ve messed up two 5020 charging batteries
I didn’t purchase because I could not find a suitable power supply to power this, any recommendations?
for now there is not cheaper and suitable power supply
I’m using a 95W laptop power brick (20V) to power my DPS5020, which has been sufficient for 4.2V20A.
I also have a meanwell 48V4.5A which I’ll be using with the RD6024, I don’t need the full 60V24A power, so that’ll be sufficient for my use.
normally people don’t need 60v/24A in the same time . only use 60v or 24a
so some lower power PSU is ok
I probably won’t ever utilize both 60v and 24a but that doesn’t stop me from wanting it. I use my RD6012 for electrochemistry and it’s been great for that, more likely to use higher voltage than high current in that application, I am just being picky. :slight_smile:
About the cheapest I saw. I have no idea how good the seller is, just pointing you to it.
That looks nice, I can’t find max dimensions for a power supply in the S800 case, but it’s very close in size to the one RD has listed on AliExpress so maybe it will fit?
for RD series power supply, use the green and black terminals to charge battery, only when you connect it in the right way, it will charge, if you connect it in the wrong way, it will not charge even you turn on the output
according to our PSU size 241*125*65mm, after install it there is not much space, so I do not know if this power supply can be put into the S800 case because its size is L250*W135*H70mm.
for now the promotion has finished, the price is normal price
hello, the RD6024 promotion has finished, for now the price has returned to the normal standard, you can get 2 USD coupon now when placing the order
https://www.aliexpress.com/item/1005003744641750.html
RD6024 feedback
it came so quickly, the quality of the product is on top, I am delighted with this device ! The seller answers all questions, the packaging is powerful and withstands Russian mail. Take it, you will not regret it.
RD6024 feedback
Fast, high quality, excellent! I order not for the first time
https://aliexpress.com/item/1005003744641750.html
Woah, that is one heck of a adjustable power supply.
Could even use it to charge ebikes.
you can use it to charge the battery
but need to use the battery charging terminals and set the correct charging voltage and current
