The L10 4-mode is actually pretty great IMO because it adds a very low moonlight mode. I got several with the recent grab bag sale. It’s not 219C, BTW. I don’t believe the emitters were ever upgraded from the original offerings years ago.
Skilhunt E3A has a LH351 B and I found it quite green. I put some Zircon minus green filter in front of the TIR and it’s much better now.
Another small budget option is the Sofirn C01S with SST-20 4000k. Two modes, starts on low (around 10 lumens and 100 lumens). I bought 4 to get free shipping about a year ago and have them stashed around the house; they get used often probably for less than a minute (e.g. look under the sofa, check inside your mouth, look in the dogs ears, etc.)
In AA/14500 size there’s also the Skilhunt E2A (SST-20 @ 4000k) which is technically a tail switch but you can leave it turned on and twist the head to turn on/change modes. Battery goes in from the head side so the tail doesn’t open. Three modes (L -> M -> H)
Jetbeam Jet 1MK is a good candidate, if you are a modder. I replaced the stock XpG2(cold white) with a 219B 4500K on mine and its a great little EDC now. Three output levels, Hi CRI LED and works with AAs and 14500s.
thank you
yes, 0.0030 is as green as sunlight, and other LH351d
the E3A only has one mode… but at least it offers high CRI and Neutral White CCT, unlike the similar models from Olight and Thrunite that are Low CRI ad Cool White.
The AAA Twisty I would recommend is the Thrunite Ti3 V2 (has 3 modes), with a 219b LED swap :
