NEW high current 60V 24A 1440W power supply RD6024 is released now
RD6024 feedback
it came so quickly, the quality of the product is on top, I am delighted with this device ! The seller answers all questions, the packaging is powerful and withstands Russian mail. Take it, you will not regret it.
https://www.aliexpress.com/item/1005003744641750.html
RD6024 feedback
Fast, high quality, excellent! I order not for the first time
https://aliexpress.com/item/1005003744641750.html
Woah, that is one heck of a adjustable power supply.
Could even use it to charge ebikes.
you can use it to charge the battery
but need to use the battery charging terminals and set the correct charging voltage and current
today is the last day we work, after today we will have 14 days holiday, we will back to work at Feb 8th and send packages according to the order date, please notice that
hello, we come back to work today. and the orders in the last 14 days will be sent out by the order date, please wait for the package coming, if you have any needs or questions, you can contact us
rdtech.aliexpress.com
RD6024 feedback
Excellent product. Fast shipping. Perfect functioning.Thank you!
RD6024 feedback
I bought it on January 8 with the launch discount, I shipped it on the 13th and it arrived on the 24th, I received it on the 26th very well packaged and without problems, I unpacked it
https: //youtu.be /nMgwQGue5qM
RD6024 feedback
Arrived in 20 days, packaged well. The block itself is normal. Added languages Russian, German, French, Russian curve.There are several output options. Connecting to the power supply is somewhat inconvenient,the connectors that are included
I’m glad you posted that, it looks like a 1500w power supply will fit in the case. Better to get a 65v or 70v power supply? I want to make sure 71v isn’t going to fry it.
Most power supplys that I have messed with have a voltage adjustment screw (A 10 or 20 turn pot). You can turn the output voltage down or up checking with a voltmeter.
Its usually located near the output wire connection terminals.
And this power supply indeed offers it, but I was just wanting to know if 70v is a hard limit, I am sure it is but want to make sure.
thank you for your message
70V is the max voltage , you can’t let it more than 70V
for 1500w PSU , you have one ? for now we did not find a suitable one (cheap and quality good)
thank you so much for help me ask the question
RD6024 feedback
very good product , fast shipping
A tip that I’ll add with fitting a power supply is that you dont have to install the case that the power supply comes with. Your installing the whole thing in a case anyways, so you can remove the power supply case sides and top just installing the bottom board that contains all the components. I used stand offs for mother boards and just installed the pcb. My power supply also came with a thermal controlled fan which I removed. Marked and drilled holes in my lab power supply case and installed it there. Removing the power supply case saves a lot of space. As long as the power supply will fit in the lab supply case and you have about 1 1/2 inches left in the front of the case it should work.
RD tech, I have a question.
Do you have updated USB meters? A lot of new USB proprietary power supplies come with extremely high current sources for ultra fast charging on their phones.
On post 40 the picture from that review, I looked on AliExpress and found what I think is the same power supply.
Power supply
I didn’t even think of that. :person_facepalming: Thanks for pointing it out!
sorry for now there is no new USB meter, because we were working for new power supply series in the past 3 years
