Utilizes GT90 LED LED with a lifespan of 50,000 hours
Powered by one 26650 rechargeable Li-ion battery
High-efficiency circuit with a max runtime up to 9 days
Smooth and deep aluminous alloy reflector creates a max 860 meters beam distance
5 output levels plus Strobe, SOS and Beacon with a max output of 6000 lumens
Humanized breathing light inside the switch, indicates the light location in the dark
Durable USB Type-C charging with 2A max charging current, 3 hours to fully charged a 5000mAh Li-ion battery, fast and convenience
Red and blue charging indicator visually shows the charging conditions
Size: 151*59*35mm, Net weight: 300g (excluding battery)
One side switch operation within one hand control
Lock-out function prevents accidental activation
Enhance cooling fins ensure a comfortable holding
Low voltage indicator reminds to change or charge the battery in time
Flat tail cap with tail standing ability to serve as a candle
Toughened and ultra-clear glass lens with anti-reflective coating
Made of aerospace-grade aluminum alloy, premium Type III hard-anodized anti-abrasive finish on the surface
Waterproof to IPX-8 standard, 2 meters underwater (ensure the waterproof cover is in sealed condition)
Expected to ship before Feb 24
If you are interested notify in this thread (not in PM)
Wait, GT90 LED? I thought this had a SBT90.2 but could be mistaken. What’s the GT90 LED?
6000 lumens and 860m throw (198kcd) is similar specs to a SBT90.2 with a 50mm head. A SBT90.2 in a light with a 59mm head could probably just hit 1000m (250kcd).
If the specs are right then this LED is a little brighter and slightly less throwy than the SBT90.2.
From the photo it looks like a SBT90.2. Perhaps it’s a clone or the v1 SBT90.
Been wondering when this would pop up on BLF. Neal has had it listed on his site for $79.95 for a couple months now. Discount seems kinda small this time if it’s in the $60+ range?
I’m hoping to get a free one or at least the head, since I’ve been mucking around with Lumintop since April of last year trying to get parts for the original XHP35HI version. They did send me a driver but it was for the ODF30C or whatever that was…totally different. This new V2 looks like it should be less throwy, and that on top of the extra dismal experience (again) with Lumintop would make it a hard pass for me. Their amazon rep mostly tells me he will check with his coworker and get back to me (it’s a repetitive game at this point) but when I recently brought up this potential with the new V2 he indicated that it wouldn’t be available until March or April - maybe he was referring to the North American market, though.
I will say that the body is a nice design, feels good in hand, and if they kept the same switch, it’s a decent one. Would rather see this in 26800, too.
My luxmeter shows 4500 lumen (ceiling bounce) and 126.000 cd for my two ODF30C V2, using a 21700 Samsung 30T.
My old ODF30C with XHP35 Hi has more throw (180.000 cd).
Doesn’t look like an SBT-90.2 to me. No square metal lens over the emitter.
Your throw estimates also seem right. An SBT-90.2 should at the very least throw over 900m in that size head, even with an OP reflector.
Along with the info on taschenlampenforum posted by sandro, I think it’s pretty clearly not the SBT-90.2.
I doubt the 6000 lumen claim. Who knows really with what seems to be a completely unknown LED. I do know that lumintop’s lights featuring real SBT-90.2’s are typically specced at 6500 lumens or even 7500 lumens. So going by Lumintop’s own overinflated numbers, this isn’t as bright or as throwy as an SBT-90.2.
On taschenlampenforum, user pho posted a measurement of 3446lm and 896m (measured at 5m). Slightly better throw than spec, but pretty underwhelming compared to an SBT-90.2.
This is a weird light. I get it has lineage, but it’s’s an odd choice. Maybe real SBT-90.2s are harder to get?
