No 26800!!!
@Johnny_Bravo
Try it with li-ion batteries. These multi chargers have only rudimentary support for NiMH, sadly. Also I’ve noticed that the capacity measurement during charging seems to take the internal resistance into account which causes different displayed capacity for two batteries with the same current and charging time.
@puglife2
Not officially, it’s just slightly too short. You can remove some of the plastic at the bottom and they can fit.
I found a little interesting fact with this charger.
If I placed the batteries before plugged to the power source, charger might not working properly.
It’s not a minus for me, just something to be aware of. Other than that, this is by far the best charger to my needs.
I won this charger in the XTAR Christmas GAW on Facebook and Instagram.
No, as an avid non-social-media person, I have not fallen off the wagon.
XTAR very friendly allowed me to deliver my input via their company website.
And now I’m looking at it. It comes with a lot of “bling” on the display.
My personal choice would have been to make that display a bit less abundant.
But when you look past that it is a very nice straight forward 4-slot charger.
If I need a charger with more elaborate tricks, I’ll still have my OPUS.
But this is a charger you can almost operate with your eyes closed.
Which can come in handy since lights with 3, or 4, or more batteries are on the rise.
My personal opinion is that everybody should at least have one charger like this.
If you discharge a Li-ION battery too far, it gets “out of reach” of most chargers.
Because at 2.X V it is considered to be a loaded Ni-MH and it stops charging it.
Where other chargers often fail, a charger like this probably can revive it.
I don’t recommend to do this with batteries you dig up from an old drawer.
But if you need that last bit of energy and have no spare on you, it can be saved.
I know that because my XTAR VC2Plus Master and I go back a looong time
BTW: nice review SammysHP.
I have only a few Li-ION, maybe I tets it some day
The Grad-function measures at discharge, or am I´m wrong?
It confused me that the results in the inner slots looks realistic, a bit more than my S4 shows but less than my C3100 shows. But I guess not all chargers load exactly the same mAh in the cells.
Testet a bit again, the 4th Slot don´t charged so far one cell to full and shows at Grad.Function also to less values.
The 1st slot worked at this try, I wonder whether it depend on the number of used cells or selected current. Mayb I get soon a QC3.0-PSU and test it again.
Update
I ordered a QC3.0-Power supply from Xtar and tried it again.
A Mediarange AA 2100mA was loaded like it should loaded
All other AAA I tried stopped at 50% load or below. Strange, some weeks ago all AAA in bay 1-3 were loaded correctly
This charger seems to be extreme bad for NiMH
Managed to load some 3 AA NiMH successfully, dunno how
But no matter which load current I selected, it was loaded at 500mA
So this charger still get the title worst charger ever (for NiMH)
I also notice this issue with early termination during charging with NiMH batteries (I use both AA and AAA, Eneloop and Ikea Ladda).
I tried contacting Xtar support, and their reply was:
“The main reason, according to our technician, is due to incompatibility. ”
I’m trying to get some more information as to what this means.
Thank you for the info.
Eneloop/Ladda are the reference, if Xtar is overwhelmed with it -> Bad products by Xtar
I bought this charger shortly after release. Keep reading bad stuff about it. Which charger would you guys recommend?
I don’t want to hijack this thread since I think SammysHP’s review should be the focus. I’ve started a new thread here to continue the discussion:
https://budgetlightforum.com/t/-/70506
What IR measurement is considered bad battery?
I think we really need HKJ to come out of semi retirement and review this charger.
I´m not sure if it makes sense. It will be no better charger after the review.
I would be more interested in reviews of newer and upcoming chargers. Vapcell seems to be interested to make chargers with properties ppl want
Today I bought Xtar vc4 plus which is considered to be the retail version of xtar vc4sl with same specifications.
I just placed a Chinese AA Eneloop which is probably in a bad condition, aged and has been over discharged before. Cell is rated 1900 mah and prior to charging it dropped to 0.9V while being used in a wireless mouse which draws very low current so you can consider it totally depleted. Charger measured 60 miliohm and started with 2A. It terminated early at 130 mAh. I pulled it out just after termination and measured voltage, it was 1.45 V and was dropping so fast so it probably reached 1.55V and that’s why it was terminated. When I reinserted it, internal resistance was measured 170 miliohms. So probably charger didn’t terminate early in vain. This time it decreased charge current to 500mA and it’s still charging while I’m writing this message.
So I guess the reason why vc4sl and vc4 plus terminates early is because temporarily internal resistance increases and this also increases total cell voltage. Since charger cares for instantaneous internal resistance but not a moving average of resistance nor an average value, it terminates early.
This can probably be avoided by choosing a lower charge current.
I wish Xtar brought more customization options to its chargers.
I would like to add something more after using the grade function for the first time. I have a very old, many times depleted, over discharged 2700 mah cell. Its internal resistance was measured 760 miliohms. Its capacity was measured 370 mAh. And it stayed at 1V almost from the beginning of discharge so these results were expected. When charging it also terminated fast so I guess charger was able to terminate very old, high resistance cell properly.
But it terminates most cells in good conditions to early, my own experience
Don´t think my VC4SL is faulty, because other ppl have the same poblem. And some other Xtar which tested at HKJ were also unusable for NiMH
And Grade is extremely slow
Grading is slow, it discharges like 250 MA current. That would be much better if it discharged with hight current first and then drop discharge current as voltage approached to 1 V. However there’s already Skyrc mc3000 doing all these and unfortunately it doesn’t have a competitor with lower price. So I cannot criticize at that point. I wish Xtar had a competitor with reasonable price like 50ish USD.
I’ll test the charger with new cells too. And I’ll check if it terminates early. But I still feel like the problem is probably fluctuating cell resistance. My old cells which aren’t charged for 4-5 years have fluctuating voltage during discharge with Xtar. This means their internal rezistance is fluctuating during constant current discharge. I fell like it will stabilize with some charge / discharge cycles.
I’ll inform you if same thing happens with newer cells and if they terminate early. I really wonder what causes this. I don’t feel like it’s a buggy software, it should be more like a component inside. I’ll try to observe it if I can find PC connector if my multimeter. Sadly I don’t have an oscilloscope at home.
By the way what’s your charge rate for nimh while using xtar vc4sl?
Thank you for posting your experiences.
I stopped loading NiMHs with the VC4SL because it´s to annoying if it stops at loading most times half the capacity or less. Maybe it works better with very low charge rate at 250mA, but I never tried it. For AA with 2500mAH, even for my AAA with 1000/1100mAH it´s to slow for me.
The strange thing, some AA were loaded correctly, most AAA not.
I only used the manual charging because I´m not a fan of automatically charging because most/all chargers use the internal resistance as reference. And I had the feeling the VC4SL with manually mode it ignores also my settings. I used 1A but it still loads with 500mA.
With my other chargers I use for AA with capacity of >=2000mAh mostly 1A, for AAA with >=950mAh 500mA. 500mA loading are supported by most chargers
For AA with <2000mAh I use my Opus chargers which also provide 700 or 800mA and with AAA <950mA 300-400mA
IMHO the Vapcell S4 Plus is a good charger/analyzer for NiMH and LiIon. The bay 1 and 4 can discharge with 1A for NiMH, the bay 2 and 4 only with 500mA.
