The RD6006W module is very interesting, it met my needs. It is easy to operate and the real-time graph of current, voltage and power helps a lot to analyze some boards. The current limiting is also nice, works well.
Not bad. This is a pulse generator, the output noise is acceptable, about 30 mV and bursts up to 100. I use transformer power. functionality is more than great. as an additional power supply is very good.I recommend to buy.
hello, it is good to see that different customers has different thoughts to make the DIY power supplies based on our models, and welcome to send us more about it, if there is question when using the products, just contact us for help.
Although it is said many times, we still want to remind you that for our RD power supply, if you use switching power supply, it is recommended to use ours or other big brand PSU, for ours, we test, for big brand, they have quality control, for others, we dont know their quality
hello, for output cables, we have 15A cable and 25A cable, you can choose the corresponding cable by the RD power supply output current, of course you can use your own cable, just make sure that the cable suppot the output current, otherwise it is not safe
The set I bought was assembled quickly when I got them, and the assembly instructions were very detailed, as well as the video. The test is done, it's very good
