1Lumen: latest reviews
Indeed.
Let’s make our calculations at 100lm/W efficiency, right?
20000 lumens / 100lm/W = 200W.
200W/3.6V = 55A.
That would equate to 18A per cell.
With that much current, everything becomes a bottleneck:
Springs, contacts, board LED wires, MCPCB trace thickness, etc.
Say ChibiM, could you check if the springs are magnetic, just in case?
I’m curious to know…
That burnt spring suspiciously looks silver with the gold plating burnt…
Also, @Sirstinky, the difference is that you still got over the rated brightness :stuck_out_tongue:
This one was wildly under the rating :slight_smile:
Now I understand why our own BLF members were so tight about production with the BLF Q8 :stuck_out_tongue:
I did a spring swap on a Ft02S a while back. They share that tailcap spring with the EA01 and FT03 I think also. Looks similar to other Mateminco products also…the outer, taller spring is not magnetic, copper alloy, the inner, smaller spring is magnetic (steel). I removed the inner spring and used a solder wick. I dislike that design somewhat because the spring pcb is really glued onto the tailcap and makes soldering difficult.
The Lumintop D3 I tested has a copper alloy tailspring
Bruh, they took the risk of not using phosphor bronze/BeCu on every spring lmao.
No wonder: at 18A, only a dual phosphor bronze/BeCu spring would allow for good performance, unless all of the coils were to touch each other.
I just checked with a strong neodymium. No signs of attraction to either the outer or inner springs. I’d say no steel present.
Thank you very much for jumping in gchart. That's really helpful
Bummer on the MF01X. I am glad I did not buy one, but I really wanted to. Hopefully they will fix.
I hope they do!
2022-04-11
Speras T3R
(Thrower)
https://1lumen.com/review/speras-t3r/
Olight Array 2S
(Headlamp)
https://1lumen.com/review/olight-array-2s/
Ooof… that Speras brand is flying a little too close to the sun with that price.
Speras are expensive lights, and I mentioned the L21B because that light does everything performance-wise (and more so) as the T3R, but at over 1/2 the price. Same buck driver, 21700, nearly identical throw, etc. If you dont need the Speras added features, I see no reason to get it over the Convoy.
Yeah, but let’s not forget they have 5 years of warranty.
That’s a bit expensive on their side.
hi
why 3.6? as far as i know should be 3.7v for standart li-ion
not that it would make any significant difference in overall calculation. but i`m always ready to learn and chance are that mentionin 3.6v you know something that i dont know
to TS. like conclustion about Speras. that is brave to compare it with another brand model in overall. usually manufacturers are damn unhappy when reviewer mentions another similar model.
Hi ChibiM
I really enjoyed the Gearlight s1000 review.
Looks like the only thing missing from the beam shot comparison, is the MicroFire Falcon H8 :wink:
That MicroFire would have burned a hole in the wall ;)
2022-04-13
Nebo Slyde King
work light
https://1lumen.com/review/nebo-slyde-king-2k/
Nebo 12K
12,000 lumen powerhouse
https://1lumen.com/review/nebo-12k/
Gearlight S1000
best sold Amazon light?
https://1lumen.com/review/gearlight-s1000/
Useful reviews and congrats on reaching 350!
Just had a flick through the ‘best sold Amazon light’ and saw this comment under the PWM section:
” I can’t quantify Hz figures, but using the Opple Lightmaster Pro’s “flicker” function, it gives an idea of the severity of the PWM duty-cycle in Low and Medium modes”.
It’s easy enough to work out the Hz from the images you provided, for med mode there’s roughly 13 pulses in 24 milliseconds which is (13/24)*1000= 541 in a second, so 541Hz.
Low mode is about 6 in 23ms which is about 260Hz.
I’ve had toooo many conversations with people about how amazing this kind of light is, which is fine as i get it’s a lot better than what they’re used to, but also toooo many times i’ve hit a wall in trying to explain they’re not as good as the marketing suggests so the actual measured figures will come in handy. Well, assuming i can get past the ‘but it lights up the side of a mountain’ block… :smiley:
Thanks for explaining how we can calculate the Hz from this. That's pretty useful, thanks.
I know what you mean. At least people should listen a bit to any enthusiast to learn a bit more. That's the great thing about talking to an enthusiast.. but some people don't want to listen :D
And if they listen, you can explain the differences with higher-end lights, and how they perform vs the Amazon ones.
I hope our measurements can be of help
Awesome. Thanks for the explanation on Hz. Yah, it’s a tricky thing. If all someone is used to are cheap light, it’s hard to explain a good light without actually comparing the two.
2022-04-22
Imalent MS12 Mini
65,000 lumens
https://1lumen.com/review/imalent-ms12-mini/
Olight Warrior 3S
Tactical EDC hybrid
https://1lumen.com/review/olight-warrior-3s/
Olight Warrior Mini 2 CU
Copper beauty
https://1lumen.com/review/olight-warrior-mini2-cu/
Nebo Luxtreme SL100
Nebo's one and only LEP
https://1lumen.com/review/nebo-luxtreme-sl100/
Natfire SF2
Cheapest LEP on the planet?
https://1lumen.com/review/natfire-sf2/
includes nice discount coupon
Gearlight S2000
Popular Amazon light..
https://1lumen.com/review/gearlight-s2000/
