I did a spring swap on a Ft02S a while back. They share that tailcap spring with the EA01 and FT03 I think also. Looks similar to other Mateminco products also…the outer, taller spring is not magnetic, copper alloy, the inner, smaller spring is magnetic (steel). I removed the inner spring and used a solder wick. I dislike that design somewhat because the spring pcb is really glued onto the tailcap and makes soldering difficult.
The Lumintop D3 I tested has a copper alloy tailspring
Speras are expensive lights, and I mentioned the L21B because that light does everything performance-wise (and more so) as the T3R, but at over 1/2 the price. Same buck driver, 21700, nearly identical throw, etc. If you dont need the Speras added features, I see no reason to get it over the Convoy.
why 3.6? as far as i know should be 3.7v for standart li-ion
not that it would make any significant difference in overall calculation. but i`m always ready to learn and chance are that mentionin 3.6v you know something that i dont know
to TS. like conclustion about Speras. that is brave to compare it with another brand model in overall. usually manufacturers are damn unhappy when reviewer mentions another similar model.
Just had a flick through the ‘best sold Amazon light’ and saw this comment under the PWM section:
” I can’t quantify Hz figures, but using the Opple Lightmaster Pro’s “flicker” function, it gives an idea of the severity of the PWM duty-cycle in Low and Medium modes”.
It’s easy enough to work out the Hz from the images you provided, for med mode there’s roughly 13 pulses in 24 milliseconds which is (13/24)*1000= 541 in a second, so 541Hz.
Low mode is about 6 in 23ms which is about 260Hz.
I’ve had toooo many conversations with people about how amazing this kind of light is, which is fine as i get it’s a lot better than what they’re used to, but also toooo many times i’ve hit a wall in trying to explain they’re not as good as the marketing suggests so the actual measured figures will come in handy. Well, assuming i can get past the ‘but it lights up the side of a mountain’ block…
Thanks for explaining how we can calculate the Hz from this. That's pretty useful, thanks.
I know what you mean. At least people should listen a bit to any enthusiast to learn a bit more. That's the great thing about talking to an enthusiast.. but some people don't want to listen :D
And if they listen, you can explain the differences with higher-end lights, and how they perform vs the Amazon ones.
Awesome. Thanks for the explanation on Hz. Yah, it’s a tricky thing. If all someone is used to are cheap light, it’s hard to explain a good light without actually comparing the two.
