I know they’re at the top end of your price requirement, but the new FireFlies models (like the E12R, T9R, and NOV-MU) have a 6-amp constant current buck driver (plus a FET if you want a bit of Turbo action). My review of the T9R is up, hopefully I’ll have the others wrapped up in a few days.
A bit less expensive, the Convoy M21C-U is regulated (an efficient boost driver) and very nice.
I thankfully have not fried mine during runtime tests, but I could see that being a concern. I’ll probably never actually use turbo on mine. It’s got a FET because they plopped the exact same driver in several lights without any modifications. Honestly, even if you’re not going make hardware changes, I would probably eliminate the FET channel using a custom config file. But in talking with loneoceans, I don’t think he even knew that the driver was going to be used in something like the NOV-MU. I’m sure he would have gladly tweaked the config if they had approached him about it.
Yeah, he doesn’t like FETs much to begin with, does he?
The driver is just entirely poorly suited to the NOV-MU. 6A is awful low for 21 emitters, but the FET channel wide-open is probably a bit much. Especially with how good 21700s are.
I love DC constant current drivers.
The ones I’m using are Convoy’s new 5A and 6A drivers, ramping drivers, Sofirn SP31, SP32, SP33V2, SP33S, SP35, SC21 and C01S. Furthermore, SP35 and SC21 can operate stably with constant current even with an external power supply from USB (excluding turbo). I use SP33V2 as a lumen standard.
I forgot another important thing.
When Anduril is physically turned on, it always starts with 7135 X1 and there is no PWM (however, manual memory mode is OFF). I often use this brightness regularly. It’s also useful when comparing flashlights.
Is there a list of current Convoys that have the 5a/6a drivers? I realized that the store listings don’t always put it in the title/product description, and I had to message Simon for clarification.
Convoy’s 5A and 6A drivers are perfectly linear. It seems to be mainly used for S2 +.
Interesting is the 4-mode driver for the Optimus T2, which works as a constant current boost driver (0.5A) for eneloop and as PWM (1.5A) for lithium-ion batteries.
Convoy’s 5A, 6A, and ramping drivers are constant current driven by current sense resistors, operational amplifiers and FETs. Since it is a linear drop-off, the control is output as heat. Not buck or boost.
