Mine arrived yesterday, I put 2 Vapcell T42s on it, I turned it on and I can tell you that it's scary !!! Brighter than Imalent MS08 and not a little I think it exceeds the declared 28000 lumens, I will do a test this evening to see how many lumens it actually emits but in the meantime I can say that it also has a decent launch and for the first minute a constant leakage sign of a '' excellent thermal dissipation ...
Interesting. Is it possible for you to access strobe? Does yours consistently take a triple tap for turbo or does it only work sometimes?
I have found mine to be very picky about the timing. If I tap too fast it does not go to turbo, and if I tap too slowly it does not go to turbo. I have to be very precise.
My sample has no LVP and it killed my P42Aâs after a runtime test. This is after the light displayed low voltage blinks as normal and then shut off, appearing to be LVP. But when I put the cells on the charger, I see that they are down in the ~1.5v range. This not like a 1S / 3V light where a lack of LVP can be tolerated because the brightness will just slowly trail off below 3V. It ran at nearly 2000 lumens (with low voltage blinks at the end) until a hard shut off.
I gave them several more minutes to bounce back and measured with a DMM. It shos 1.9V and 2.1V. Is that still too low to be salvageable?
So how many amps do you think itâs pulling on turbo? To get that 28,000 magic number I was thinking about 50-60 amps. Is the tail switch electronic or physical? Switches and springs start melting at these levels unless they were really designed to do so. Did you see any signs of spring over heating?
Itâs a mechanical switch. Reverse clicky. I am not sure about amperage but itâs very large, much larger than most other switches. Here it is on the right, next to a Convoy 18650 switch and a Convoy 21700 switch.
Here is is next to an L7 switch.
The spring shouldnât be a problem either. Check out this bypass design. Very clever.
I see. Thank you for the info. I will contact Neal and ask about this. Perhaps he will be willing to send me a replacement driver if mine is indeed faulty.
Where you have see low voltage protection?
Always only write a third function, Low voltage warn.
Not only on this light, in all Nightwatch light, Only low voltage warn.
1 reverse polarity
2 control temp
3 Low voltage warn
All UI and function or copy and paste light after light
You need to charge those at very low current, like 100 mA to safely being them back. I have done this with success even on super-dead 18650 from laptop pulls at like 0.8 volts. They do take a capacity hit and discharge current will not be as good so those p42s might be relegated to under 10 amps. Youâll know if it is successful if you let the fully charged cells sit for a couple days. If the voltage drops rapidly like 1 volt per day, then theyâre junk. You can try another cycle of very low current, but it might fail again. You can also do a discharge test at 1 A. If the voltage drops rapidly, theyâre permanently damaged.
