26800 will also discharge continuously at 25 amps. However this maybe the cell for those lights that can’s convert to 26800. Yes, the 26800 length fills my hand better.
I’d have to go dig up receipts but it would have been a US supplier…probably Illumn but maybe Liion Wholesale. They’ve been good cells. Not getting as much use over the last year since I converted most of my 26650 lights to the Queen Battery 26800 cells.
The Vapcell red 26650 5500mah tested the same as the Shockli 5500mah. They were the best 26650 in existence. Unfortunately manufacturers stopped making 26650 flashlights few years ago since 21700 cells came out. If we get a super good 26650, that would convince flashlight manufacturers and maybe other device manufacturers to start making 26650 products again.
Thrunite Catapult V6 and Lumintop ODL20C V2 also new 26650 releases. Looks like Lumintop went with 26800 for the new D3, though.
26800 is where it’s at for fat cells. It offers more than any 26650, still, although it sounds like this new 26650 may be a great general purpose choice with more capacity for replacing cells or in lights that can’t (or don’t wanna be) upgraded with longer tubes or adapters. For new lights, it makes the most sense to go with 21700 or 26800 though. In the nonflashlight world there are still plenty of devices that were designed for 26650 (and cheapie flashlights, too) so they’ll need good cells as well.
I would like to report having self-discharge and overdischarge issue with possibly some Vapcell K62 26650 batteries, based on my purchase of 8 pieces of them.
I purchased 8 pieces of these Vapcell K62 2600mAh 26650 from a local reseller.
All of them arrived properly sealed/shrink-wrapped.
I reported the discharged batteries to the local reseller, and the local reseller asked if I can use reactivation charger to charge the 2 pieces over-discharged batteries.
I was able to charge the 2 over-discharged Vapcell K62 (monitoring the batteries temperature when they were nearly fully charged)
(For the 6 pieces batteries (3.78v and 3.66v), I left them as is and did not try to charge them yet — I plan to observe if their voltages may continue to drop.)
Now for the 2 pieces, after I “reactivated” the over-discharged batteries, I did a round of capacity testing (charge to 4.20v, discharge at 1Amp to 2.50v), and the results are 6208mAh and 6057mAh
After finish charging, I did not use the batteries but left them unused on the table at room temperature (room temperature here is probably around 30 degrees Celsius)
very fast self discharge for one of the over-discharged batteries:
tested voltage (a few hours after charging) … 4.125v
32 hours later … 3.849v
another 14 hours later … 3.66v
from 4.12v self-discharge to 3.66v in around 2 days.
for the other over-discharged battery, it appeared to be a bit better:
a few hours after charging … 4.170v
32 hours later … 4.159v
another 17 hours later … 4.151v
(I think this may still be considered normal? will observe a few more days)
