My Xtar VP2 will overcharge
At charge end, the display always shows the cell voltage, not the set voltage (because a new charging cycle has not begun). I had both bays populated so I don’t know what would have displayed for the switched voltage. It’s definitely possible I didn’t notice it displaying 4.2 before pulling the cells off.
I was able to reproduce an overcharge a second time after verifying the switch and display voltage was correct, but I only let one cell go to 3.7 (and the display did show that for the populated bay).
I’m going to try bringing it up to 3.7 once more with a sacrificial cell just to make sure I’m not going crazy, and hopefully I can get a photo of that along with the empty bay displaying 3.2 to show Xtar customer service.
Status update: I unwrapped 4 unused LFP 16340s (Tenergy) that were in my ‘backup’ stash last night, checked voltages, which were correct / nominal, discharged them to ~2.8 V using my Opus 3100, and let them sleep. Today I set the switches to the ‘3.2V’ nominal voltage setting for this chemistry, loaded the cells into all 4 bays of my 2 VP2s,and powered up both chargers. All indications as displayed during initialization were normal / as expected. After normal indications during the charge cycle, it was displaying the correct ‘3.6V’ CV charge value during the final stages, and the charging cycle terminated around the expected time with green LEDs on. The displayed cell voltages have drifted downwards exactly as expected so far - to the expected current displayed values of 3.35 / 3.36V at this point, which is 2 hours after termination. Since I’m home and awake for the duration of the evening, I’m going to leave them sitting, untouched, to monitor for anything unexpected. So far, all is / has been exactly normal and as expected. I’ll update after letting them sit until ‘down’ time. Just wanted to update you at this point.
Cheers!
Note: I have edited this post to eliminate some text I had erroneously inserted which incorrectly stated the initial voltage displayed upon power-up / initialization.
Thanks again, Desertcat. Here are my most recent findings.
I was mistaken about the display of the end voltage: Mine had been sitting green on the charger for about 24 hours now, and the display read 3.60V and 3.20V (on the empty bay). But as soon as I re-started the charging cycle, it displayed the actual battery voltage of 4.22, confirmed with a multimeter.
So, once it reaches normal charge voltage, it either freezes the display, or stops checking its voltage (or both), but then continues charging it. I’ve got it on video for Xtar support.
Just making sure: your charger’s displayed voltage at end-of-cycle drifts down without any action taken on your part? That alone points to a defect or a manufacturing difference with mine.
No, it doesn’t. Cells will settle down a bit, after charging subsides. With older cells, or shitty cells, the amount might be more profound.
That doesn’t explain your ‘4.2v’ termination with 3.2v LiFePO4 cells, but settling is common.
Chris
Hi Chris, I’m referring to the voltage display of the cell at end of charge. I expect the cells to settle, I’m just trying to clarify if the charger displays the actual voltage of the cell as it is settling. Because mine does not… it seems to stick the display at 3.60 regardless of the actual cell voltage, until I restart the charger.
That must be how I missed the overcharging at first, and if any others’ chargers are behaving the same, it’s possible they are missing it too.
Are you measuring things with a quality volt-meter?
Chris
And is the DMM battery still good?
The display voltage, multimeter, and Anduril voltage display agree.
Let me get back to you later after I review this further, but I think from the discussion I’m beginning to understand what you’re seeing - but unfortunately, not what’s causing it (root cause). Here’s something to consider for now. If you’re seeing what you indicate, and I understand correctly, your charger is indeed likely overcharging (too high voltage), and I’d recommend you stop using it until you get it sussed out.
It sounds like your charger is indeed charging to an incorrect CV value which is much higher than the correct 3.6V, and is likely exactly what your voltmeter indicates. If it is higher than 3.6V, which it should NOT be by any significant amount, the VP2 will not show the correct value - it will only show 3.6V, although your voltmeter certainly will and apparently does.
The key is this: Go back to your LYGTE link to the test / review, and I think you’ll see why after completion of the charge cycle, what you see on the VP2 display, and what you see if you check the batt voltage w/ your voltmeter do not agree, and it’s apparently because the charger is exceeding the correct CV phase voltage. Here’s the key text:
The voltmeter has a good precision, when charging it will show slightly above the battery voltage, as expected. Sadly it will not really work above max. charge voltage: it will show one value and then stop updating.
So, if it’s overcharging (voltage), you will not see it on the VP2 display, but will only see it with your meter. Believe the meter, because it will be the correct value. Good thing you have one, just for situations exactly like this one.
So that only leaves the question of why your charger is charging to CV value approprate for a 3.6/3.7 V chemistry cell (which is 4.2V), instead of the CV value appropriate for your 3.2 V (LFP) chemistry (which is 3.6V). If so, it’s a serious malfunction of the VP2, which is why I recommend not using it at this point.
Given that text from the review (thank you LYGTE), this is starting to make sense to me. It probably means your charger has a fatal problem, which is not good news, but at least it’s making sense.
Is this making sense to you too, or is it just me:-)
It makes perfect sense, thank you.
I noticed that my VP2 did not have that yellow anti-counterfeit sticker that’s pictured in the review thread (Test/Review of Charger Xtar VP2). Maybe mine is a fake. Illumn might want to know about that. I’m bringing this up with them first, and will check with Xtar if they don’t have an answer for me.
I’m actually watching / noting some numbers on a charge right now, and will have a few further comments at some time, but that stuff is all academic at this point Your observations noted in your posts have essentially proven that your specific VP2 is defective (which is rare, it must be said), and LYGTE’s excellent (and important) observations I quoted above have determined exactly why what you were seeing was (justifiably) confusing (due to a design deficiency that your failure exposed in the VP2), so you’re ready to take action on the charger resolution. You have all the information anyone you excalate to should need - unless they want photos or something). Again, I would not continue using that charger at this point given what you’ve seen.
Yes - Both of my VP2s DO have the yellow stickers on the front which appear to be the same as the one pictured in LYGTE’s test. Its absence on yours is questionable I guess. Just FYI, I purchased both of mine ~5 years ago from Battery Junction.
Anything can fail. That said, anecdotally I don’t recall hearing of any serious failures with VP2s - primarily just dimming of the displays over long periods of heavy use. Perhaps a non-critical failure I’m forgetting, but the falure you’re seeing is what I consider a “serious” and “critical” failure (one that can cause further damage). That said, it may sound crazy, but in your situation I would still consider replacing the failed unit with another properly-functioning VP2 - and that would be underscored further if the authenticity of your unit proves to be suspect.
Again I’ll follow up a bit on this, but you pretty much know what you need to know to deal with the unit you have.
I hate to tell you this, but I just noted that some sort of malfunction happened with one of my VP2s tonight while I wasn’t paying attention. It may be similar to the overcharge problem you observed, and is nothing I’ve seen before. Mine appears to have over-charged a cell that I left in the unit unattended for quite a while following a normal charge cycle (knowingly), and when I started to put things away a few minutes ago I just noticed it. There may be more to this than I thought, and it’s possible that your unit may not be just an isolated failure, and one of mine may have exhibited a similar failure - which means this could be a design issue here rather than a one-off failure as I thought. I’ll be investigating further, but for now, be aware that there could be more to this story than just a single failure with your particular unit. It doesn’t change what you saw or the failure you experienced, or your efforts to possibly get your unit replaced, but the issue may go deeper than that. Obviously more testing is now required on my chargers, and I’ll let you know what I find. If what I think happened actually happened, I may be looking for a replacement for both of my units - which of course isn’t good news:-(
I have a Nitecore D2 charger that does LFP somewhere. I plan to test that in the same way next. Hopefully you, I, and that unfortunate fellow with the UMS2 in the other thread aren’t in the process of uncovering an industry secret that LFP charging mode in consumer chargers is complete BS.
It seems unlikely, but then again a host of otherwise very thorough reviewers never talk about what happens when they leave cells on a charger, because that’s not something anyone recommends.
You may want to ‘hang loose’ on this, as I think I may know where this VP2 train is leaving the rails, and the VP2s may remain usable for us as long as we adhere to ‘best practices’ - meaning the problem may be both predictable and avoidable. You may not want to escalate this functional issue regarding yours, as it may well be ‘in the design’; however if you believe your example may be a ‘fake’, you likely should escalate that issue, which in my opinion would be unacceptable. I’ll do some testing since I have 4 cells I don’t mind sacrificing, and will follow up with additional info which has come to light (as a result of re-reading LYGTE’s excellent test results even more closely). BTW - those referenced Nitecore charger issues sound unacceptable to me.
Update: illumn is pulling some samples from stock and testing on them.
Weird. Xtar chargers have Been reliable so far with no issues
Just checking, are you saying your VP2 does not do this?
fran82 -
There could be a little ‘group think’ involved, which is insidious and can thrive in forum environments - and like rust, it never sleeps, and without intervention can keep growing.
It’s also a mistake to assume that a company which builds a number of great products necessarily builds ALL great products. All too often, that is not the case, and it’s best not to generalize.
Keep in mind that the VP2 was likely designed almost a decade ago, so there’s that…
Lastly, and in this case probably most importantly, some otherwise great products may have a single, serious problem which may only be evident in ‘edge case’ situations and thus may be only rarely seen by a few users. The jury’s still out on this one (but not for long), and at this point I suspect this is the situation that applies here. Stay tuned…
Achilles’ Spiel -
Testing - one - two - three!
I’m doing the aforementioned testing, but as you well know, testing for this problem takes a good bit of time. Stay tuned, and I really expect that a definitive, conclusive answer regarding this issue will be forthcoming this weekend.
Just send it back in and buy another one, or not.
It’s not functioning correctly.
Chris
