Hello, today is the final work day in April, and we will have a 5-Day national holiday, during this time, we do not work, and we do not send packages from our China warehouse, please notice that we will send the package from May 5th
RD6006W feedback
very good I liked it a lot
https://www.aliexpress.com/item/4000282551930.html
hello, if your RD device is damaged, you can contact us for help, we can see if it can be repaired, sometimes just the fuse burnt, you can replace the fuse and it is ok, and like this customer, the screen is damaged, we send him the screen and video instruction to fix, it is ok
RD6006P feedback
power supply is excellent! packaged very carefully! From the back, the circuit design is very compact and elegant, and the workmanship is fine. It took about two hours to assemble at night (please see first Instructions will save time)
www.aliexpress.com/item/1005002185722889.html
RD6018 feedback
There are no problems with delivery and packaging. Thanks seller.
https://www.aliexpress.com/item/1005001488070904.html
RD6012 feedback
very good team .... regulates perfectly
https://aliexpress.ru/item/4001053200176.html
RD6024W feedback
I received everything, it arrived in a few days. There are no defects, I am satisfied with the purchase.
RD6006P feedback
I have to say, this power supply is definitely value for money
https://www.aliexpress.com/item/1005002185722889.html
RD6018 Feedback
I have tried all the functions so far. The charging function is very good. The power supply is very useful. It solved the problem of high current. They answer all questions, The next step is to wait for the silicone wire. perfect shopping
RD6024W Feedback
Everything is fine, delivered in 3 days(From RU warehouse)
https://www.aliexpress.com/item/4001053200176.html
RD6024 feedback
my wooden case is not bad too,haha
https://www.aliexpress.com/item/1005003744641750.html
RD6024W feedback
Collected everything, it works. Made with high quality. Until I figured out the settings.
RD6018W feedback
Works perfectly, very accurate very impressed, I 3-D printed a case for it and power supply, love this thing
http://aliexpress.com/item/1005001488070904.html
RD6018 Feedback
Great kit!!! I chose different converters for a long time and ultimately settled on this kit with a modification with a current of up to 18 A. For my needs, this should be enough with a margin. I have not tested it to the maximum yet, but what I managed to check fully corresponds to the declared characteristics. The indicators on the screen correspond to the parameters output to the terminals. I ordered on April 28 with delivery from Russia. On the same day, the order was shipped from the warehouse and already on the evening of May 1, it was loaded into a parcel terminal in Moscow. Super fast delivery! Everything was securely packaged in a cardboard box. There were spacers between the box and the body to protect against damage. The power supply sealed in film was inside the case, which was also protected by a package from scratches and damage. The converter was in an individual sealed box. Now I'm still waiting for 25 amp probes from China from this seller. I recommend the product and the seller!
RD6006P Feedback
Very very good power supply the wifi works with pc very good quality ,thank you for the gift
RD6012PW Feedback
excellent product, easy to install, premium build quality, helpful seller, top performance.
https://www.aliexpress.com/item/3256803286017579.html
RD6018 feedback
Quickly deliver
https://www.aliexpress.com/item/3256801301756152.html
