Without going into the details as this was sooo many years ago; Ray-0-Vac had these “Renewal” chargers for alkalines. Got one for AA and sure enough recharged some cells. And as stated in the above quote from manithree, didn’t fully bring back the capacity. Also, not all Alkalines would work. The older models of Duracell would, but they changed the chemistry (wouldn’t want to kill a very profitable disposable product line, would you?). These newer batteries wouldn’t do anything - no leakage nor any heat.
It was said the charge profile was a square form with periodic ‘rest’ periods. Either pulsed or other. Not well understood at the time.
Using a standard NiCad/NiMH charger I wouldn’t attempt. I’ve had so many leaky Alkalines that these “destroyers” are my main reason to convert about anything to Li-Ions.
Yeah, back in the day, there were “battery fresheners” that would indeed force back something of a charge to fading cells.
But cells had thicker walls back then, so even completely spent they’d rarely leak. C-Zn cells sometimes, alkalines rarely(!!).
Today’s “efficient” cells use so little material in the walls that it’s a race between developing a hole and thus a leak, or someone tossing moribund cells.
Can’t fathom why manufacturers make modern-day meters with a 2.8 Volt threshold. Can’t use Laddas (NiMH).
Just found a small 13 x 48mm Li-Ion cell buried within a disposable Vape Mod – chucked alongside the sidewalk. Seems to be able to charge. Will be looking into adding a charging board and 3-volt regulator. It would fit in one of those meters, and then bypass the auto-off function (user selectable from the ‘ON’ button sequence).
I see ”16.2+” in Zeroair review with sofirn cells (60mΩ) and LH351ds, 219bs having lower Vf will pull more current, and if quality cells (e.g GAs 30mΩ) are used then even more current, I’d say it will be too much for 219bs.
Ah, I see what happend. I was reading 1lumen’s review instead of zeroair. Zeroair has the Anduril 2 driver. On 1lumen’s review and it says
“Bottom of ramp (moonlight): 2.5mA
Top of ramp: 4.38A
Turbo:
Sofirn Cell: 10.9A
30Q – 11.9A
The light seems to cap out at the ~12A mark which may be a hardware limitation”
I took a plunge and tried it this morning. I reflowed sw4500k and it’s working. Visually, the SP36 on step 7 is about the same as a D4V2 SW4500k (9a, turbo, floody) from 20 feet away. I will have to wait for night time for wide area test. The first revision SP36 hardware limitation became a feature. Maybe that’s why it’s heating up faster than expected for its mass. Now I just need to find a way to diffuse the beam even more.
Yeah, sometimes it’s “go or bust”. Nichia’s 219b has a reputation for being low Vf. It may deter the life of the LED, but as you seem to grasp that the battery doesn’t always deliver those Amps, may just work out.
Still, if you draw 16 Amps at the tail, you’d be pushing those LEDs at the very max. May not burn out immediately, but will eventually fail.
Now that the dust has settled a little, just how good is the Nichia 519a emitter? Do they match the output of the LH351D emitters while having better R9 and tint?
Is it harmful to ceiling bounce UV light without safety glasses? Do I have to watch out for mirrors in the room? I will be using the Wurkkos WK30 365nm.
The prescription is to not have the light shine directly into the eye(s) or on the skin.
It’s not a laser. Any reflected UV or indirect exposure is relatively safe – not prolonged though.
No. No idea who he uses to make and program all his drivers now but doubtful they’d give up their work freely. You could always message Simon and ask if sharing it is possible.
Awesome! Thanks for this. The output of these two emitters is not as similar as I had hoped. Looks like the LH351D was a cooler bin which might have exaggerated the difference but overall I guess the LH351D still wins for output.
And the CRI of the chosen LH351D is terrible. That comparison is simply highlighting something that I think just about everybody here already knows: There’s a price to be paid (in lumens) for high CRI. If you don’t care about CRI and tint, then the 519A isn’t very interesting at all.
