What about a Sofrin SP10 Pro? Although it is a 1 AA light with Anduril 2. Not sure how well it would perform when the floor and ceiling set to the 5 lumen range.
+1 for the Sofirm C01 at 3400K from Sofirn Store on AE and they also have the Red LED in same form factor.
If you are so inclined and prefer more runtime, a warm 5mm LED tweaked to fit a 2xAA Maglite might serve your needs as well. The tweak is a matter of resizing the LED and reflector, then pairing with rechargeable constant 1.5V lithium you can get consistent regulated output for days.
Here is photo of 5mm Yugi 3200K Hi-CRI in -
1xAAA on left, Mini Maglite 2xAA on the right
Those gchart joule thief drivers are excellent. I swapped one into aNOS four sevens atom along with a 219b sw35. Just an awesome little light. I agree with others, though. Sounds like the Sofirn c01 is exactly what you want. Alternatively perhaps peak can make an Eiger to suit you?
Search for medical pen lights. Most have a very warm emitter, several good ones to choose from (and they aren’t priced like typical “medical” tools, thankfully). Lots of the weird-name cheapies do use a 5000K or 6000K emitter, though, but most of the med-specific stick to 3000K.
Weltool has a couple…not sure if the multi-mode brighter ones would suit you but single mode does limit your choices. Nitecore and Streamlight have some that I know are well regarded by EMTs and nurses, and seems like Wuben and Lumintop also have one (but I think the Lumintop may not have a suitable mode for you if memory serves).
I used the very light you’re looking for tonight. 2xAAA incandescent maglight. Mine with eneloop is quite warm 2300-2500CCT maybe. Only one mode and right around the lumens you want. 100CRI to boot!
Wurkkos WK02 penlight. 2*AAA, moonlight mode and 4000k SST-20 95 CRI.
Maybe they have them on their site if you don’t like AliExpress.
There’s also. WK01 that’s a single AAA but the warm version is sold out.
Nah. I have a Lumintop iyp 365 which is very nice if you like MLH mode order. I use the Ultratac A3 at work for its LMH mode order and it’s very very decent. 219C but very good tint.
Both have beam patterns like every other AAA sized reflector led out there.
The nice thing about one that I linked is that it has modes but always comes on in the lowest so you never flash a patient accidentally. They’re specialty lights, though, not really at all like most pen lights or our regular small cell lights.
EDIT: Forgot to say "Welome to the Forum" to new member S2000.
With the large variety of lights I have purchased, it is somewhat disconcerting to admit that the lights I use the most are my reverse clicky tail switch "UltraTac A3" Pen Lights with two NiMH AAA batteries.
I prefer the longer thinner 2-cell AAA form factor with a tail switch compared to shorter single-cell AAA or thicker AA lights because they are easier for me to handle without fumbling around and they carry discretely in either a shirt or pants pocket when using a clip (and sometimes I carry an extra or two as emergency spares).
UltraTac lists the Lumens as "2 for Low", "30 for "Medium", "220 for High" and the LED as a >90 CRI Neutral White Nichia 219CT.
The "UltraTac A3" has "no memory" and defaults to "Low" brightness when turned ON if it has been OFF for at least 2 seconds, otherwise it cycles through the modes (Low, Medium, High) and repeats this cycle with full ON & OFF presses of the tail switch which occur faster than two seconds. While ON, half presses of the tail switch at any speed will cycle through the modes (Low, Medium, High) and repeat.
I am not sure what actually qualifies as a "Medical Light" and I do not need a medical light, but in their Amazon listing, UltraTac states the "A3" is a "Medical Pen Light", "Designed for Medical Personnel" and "Suitable for pupil inspection" but the beam from my "UltraTac A3" lights is rather floody and not tight and that is the beam pattern I prefer for my use cases.
This was the Amazon Listing for the "UltraTac A3", but unfortunately the "UltraTac A3" now shows as "Currently unavailable" (they were a great BudgetLight Buy at $10 each and I purchased 5 of them last year):
I would be curious to see how the $32 "Nitecore MT06MD with Nichia 219B LED" mentioned by Correllux compares to the the "UltraTac A3 with Nichia 219CT" and I may have to purchase one to find out since I have not experienced the "legendary" Nichia 219B LED which I have read so much about.
You said warm but also red. Do you want a warm white, or just straight up red? If you want it to be red, besides the C01/C01R, your best bet might be to just put some red film on the lens.
Or if you mean warm as in orangey, I agree with an incandescent maglite. Take a look at this: https://www.amazon.com/dp/B00002N9ET/
Dim (only 2 lumens claimed) and low color temp because incandescent.
I hope UltraTac is still a thing. The last 2-3 years they seem to be really under the radar and without stock to sell (or not much)…no response to customer service or amazon messages, either. I have a couple of their small lights and they have a good thing going. I hope they don’t disappear for good (like Rofis and so many others).
“Medical” light…some specific purposes and desired qualities but it does depend a little…not written in stone. I’m no expert here so what I know comes from some PA, nursing, and EMT friends, but that very low 5 lumen range in a warm temp is apparently the best for eye examination and doing “the check”, which I guess is more than just pupil reaction and size. It’s dim enough not to blind or cause any flinching and blinking, which can be important. For other uses like skin tone (lips, gums, nailbeds, etc) then brighter and higher temp seems acceptable, and high CRI certainly preferable (this is one reason why they have stuck with incandescent bulbs for so long). I think that matters more to them with black/brown skin pigmentation where it’s easy to miss or misjudge signs. That said, I hear that some people want an even lower lumen output like 3 lumens for eyes…maybe it depends on what they’re doing. And 50 or 100 lumens seems like it would be fine for general close work and skin tone but possibly harmful to the patients for eye checks, especially if they are not conscious/responsive. Like a lot of things there aren’t rules about labels and marketing terms, so anyone can call anything an X-type light I guess. I’m not sure if OP was looking for a light for medical use or not but they described it to a tee, being quite specific about 5 lumens and a single mode. There are many very good and excellent pen lights these days but the low-lumen med types are still kind of unique. One of my PA friends got by with some cheapie ribbed stainless incandescent model for most of her career (and she worked for a neurosurgeon)…one ER nurse friend had cheapie plastic jobs and a Welch Allen one that she thought was terrible and kept in her car instead. I would imagine that Welch cost a mint, knowing them…my old HID bike lights used parts from them and the price on dinky ballasts and fragile bulbs was bordering on criminal.
