【TS10V2 Al available】Wurkkos "slender waist" TS10v2 aluminum version available with black,green,orange
Thank you! Looking forward to a review with color and CRI measurements!
Not sure, if it is compatible with AA, it will lose some performance and the output will be less
I just got a word with Clemence (ERKX), showed him the emitter datasheet and he said it could be a straight Nichia E21A swap. Not 100% sure because i don't have it on hands but soon (hopefully) i'll report back with some mod update. :)
Man these emitters are skinny! If you’re going to mod, get out your super fine hair tip tweezers. Data sheet isn’t all that encouraging, compared to emitters we are used to using. The reflow characteristics hint at users being able to do it right and do it quickly, and be able to control the temperature decently.
Specs say a total thickness of +/- 0.32mm. That’s including the phosphor. That’s about one half of a B35AM and those are pretty thin! For the SAE among us, that’s about 0.013”, thirteen thou….1/64” is about 0.015”. Looks like the base is something around half the thickness (phosphor being the other half). Sounds easy to damage the edges/surface of these with typical small electronics tweezers. Also seems like a candidate for using a stencil with solder paste…those pads are teeny tiny.
Any estimate on when those other CCT options will be available? Also Ice Blue and Orange sold out, I shouldn’t have waited lol
So my house was robbed last week and they took my KR4…I came on here looking to find a reasonable replacement and sure enough, here it is…but it looks like I missed out on the Orange one. Any ETA on a new batch?
I can solder very well, what size are the aux LEDs?
Orange with a battery seems to be in stock still. Orange without a battery is out of stock along with both options with ice blue aux. Even if you don’t need the battery, it’s only 2 bucks.
On their site? I see Orange and Ice Blue as being out of stock no matter which options are selected.
OPS, sorry when going to update the 2700K CCT, i found it was 1919 size, so have to wait next batch of other CCT options
Thanks!
Good luck with the mod. I’ve swapped the TX in an i3E. One hit and one miss. Three tiny LEDs at a time will be very difficult I guess.
10 more blue color release from the unpaid orders.
I’m pretty sure it’s linear. 14500 only.
It was definitely listed as in stock when I checked yesterday, but no longer. Blue is back though.
Does anyone know if this light requires a flattop/button top cell? Or if either will work just as well?
my understanding is both will work!
sold out?
Sorry to hear that. They apparently knew a quality flashlight when they saw it though.
Do be aware that this is a smaller light than the KR4, running on a 14500 battery instead of an 18650. It should be a great pocket light at a very nice price, but the maximum brightness won’t be as impressive.
I appreciate it…apparently they knew what quality pistols (Dan Wesson), a display case full of ST Dupont lighters, and a whole bunch of other stuff were.
Yeah, I currently carry a Wowtac W1 (Thrunite T1) modded with a LH351D (4?K…I think). It’s nice, but wouldn’t mind something with anduril. The KR4 was only 2k/lm I believe. I ended up ordering the Red aux one so I don’t miss out. I can always change them if needed.
Thank you for all support , the first batch sold out already,
so what body color and aux color you expect for next batch? :person_with_crown:
I would prefer cyan and green as body colors.
