Thanks for that!
I learn something new everyday.
Thanks for that!
Thanks. I know about the message you can leave when placing the order. I was just wondering if mentioning what CCT you want works with them.
Sometimes sellers offer free gifts with the purchase but you need to leave a message to remind them.
Also one god tip is to use the app because the items are cheaper, you get coupons and other stuff.
Yes to titanium! Please, just take my money!
S21d seemㄴ be sold out.
When will it be in stock?
The color of the switch stalk doesn’t matter. It’s the same switch.
The 16MM PCB is much better than a 17MM PCB though, because the 16MM one will fit in Simon’s 18650 lights without having to modify the PCB.
Do they mean only cool white? That’s a shame, a number of lights would benefit from such an led.
Hi Simon. The 17mm forward switch I got is a bit different from the one pictured. the switch has a black top instead of white top and the mcpcb has 1 center hole instead of 5 center holes which is exactly like the 16mm switch pcb. it measures just under 16mm like your 1288 16mm switches.
Sorry, the picture has not been updated, it is the same except the color is a little different.
Simon Mao: Azirine:Is the rumour about a new warm white thrower LED true?
Sad news, the manufacturer says only white light is available.
I once made a suggestion to the luminus company that they would make some SST40 SFT40 warm white and neutral white.
So far, this suggestion has not been adopted.
Hi Simon, any plans for adopting xhp70.3 hi in your lights?
Andometto:Hi Simon, when do you expect the T4 in white to be available? Can I buy it now without the gift box? Thanks.
ok ,only 20 pieces T4 MAO without gift box in stock ,i will add a link tomorrow
Any update on this? Really interested in this light.
only 6500K
519A 2700K available now
Fantastic news!
Considering the uniformity of the light spot, the reflector used for the 519A flashlight is now changed as follows.
orange peel for following models: S2+ S21A S21B
smooth reflector for following models: M1 M21B C8+
If you wish to use a different reflector, you can also indicate your request in the order remarks.
smooth reflector for following models: M1 M21B C8+If you wish to use a different reflector, you can also indicate your request in the order remarks.
I think that is a sensible decision!
Simon- will there be green AR coated lenses available as a separate order item? I could not find any listings in your store, and the lenses that are listed do not specify coating color. Thank you, kindly.
AR coated lenses for which flashlight models?
What is the current discount code?
I just ordered an S3 without using a code. Simon’s prices are already amazing for the quality, selection, and customer service he offers.
Chatika vas Paus:What is the current discount code?
I’ve placed two orders of over $100 each in the past several weeks and always forget to use the code.
Oh well. I still got a great deal each time. I consider what I could have saved being a tip. Simon earns every penny.
