Lithium Primary
11 posts / 0 new
LunaLoves
Last seen: 2 hours 22 min ago
Lithium Primary
Hello,
which small and common AA-torches are suitable for lithium primary use?
I know that since the voltage of those batteries is slightly above 1,5V some torches don’t like them
I’m planning on leaving the torch in my car for very long periods of time and it will get cold which is why I’d like to use either AA-Lithium or CR123A batteries
Correllux
Correllux's picture
Last seen: 7 hours 14 min ago
It might be easier if you give some models you’re interested in? Someone correct me if I’m wrong but I think the only issue with their as-new slightly higher voltage crops up when a driver is made to accept dual fuel with AA or 14500 where some have voltage sense limits below the lithium metal primary. The Lumintop Tool and original non-14500 Convoy T2 both do fine. I think Simon is going to address the issue on the T2 with later version drivers. Nicron N7 adjustable angle head does fine, the now-unavailable Rofis R2 does fine. Totally forgot to check on my light, but the Sofirn SP10 Pro might take them (could check that thread for comments, too).
The chips and circuits themselves should have no trouble at all with the couple extra tenths of a volt but if the MCU and associated sensing is too tight then that’s where you’ll have problems. All single cell 1.5v lights need to be boosted up to 3v-ish by the driver anyhow.
LunaLoves
I was actually looking at the T2 and T3 before but only saw the dual-fuel one and assumed it had the same voltage issue
So the regular AA version works fine with lithium primaries?
zoulas
zoulas's picture
Last seen: 2 hours 16 min ago
CR123A is the preferred battery. Readily available.
MtnDon
MtnDon's picture
Last seen: 8 hours 36 min ago
I have never used a regular version of the T2, but no other devices of may kind that I have ever used a primary lithium cell in has ever had a problem.
LunaLoves
Which cheap CR123A light would you recommend?
The first 10 or so results on parametrek arant avaible anymore
zoulas
zoulas's picture
All I can say is that in home depot they sell 10 packs for $10. That’s not bad for a solid battery.
If you want cheaper, you may have to look online and get batches of 100.
LunaLoves
I was talking about the torches, not the batteries Smile
wle
wle's picture
Last seen: 1 day 17 hours ago
CR123A
these are super good and super cheap
https://www.aliexpress.com/i/2251832723988128.html?gatewayAdapt=4itemAdapt
super small too
$2.47 !!
    Daniel Behrman, "The Man Who Loved Bicycles".
-Greg Lemond.
BlueSwordM
BlueSwordM's picture
Last seen: 7 hours 26 min ago
Convoy T3 with the 12-mode driver and a AA ltihium primary.
jon_slider
jon_slider's picture
Last seen: 7 hours 27 min ago
the SP10 Pro, and it is on sale
code S7ECOBGO
or if you want a simpler UI, Lumintop Tool AA, or any other AA you like except for the Convoy as others have pointed out.
