【convoy】H4 and B35AM options are updated
only 6500K
519A 2700K available now
Fantastic news!
Considering the uniformity of the light spot, the reflector used for the 519A flashlight is now changed as follows.
orange peel for following models: S2+ S21A S21B
smooth reflector for following models: M1 M21B C8+
If you wish to use a different reflector, you can also indicate your request in the order remarks.
I think that is a sensible decision!
Simon- will there be green AR coated lenses available as a separate order item? I could not find any listings in your store, and the lenses that are listed do not specify coating color. Thank you, kindly.
AR coated lenses for which flashlight models?
What is the current discount code?
I just ordered an S3 without using a code. Simon’s prices are already amazing for the quality, selection, and customer service he offers.
I’ve placed two orders of over $100 each in the past several weeks and always forget to use the code.
Oh well. I still got a great deal each time. I consider what I could have saved being a tip. Simon earns every penny.
adirus wrote:
Hi Simon, any plans for adopting xhp70.3 hi in your lights
simon wtote: only 6500K
There's a youtuber from Thailand, Weerapat Kiatdumrong; he's comparing M21b xhp70.2 4000k with xhp70.3 hi 5700 Hi-CRI.
The beam of the Hi is slightly more focus than the domed 70.2. Both perform good.
Has a spectrum analysis been done on Simon’s FC40 5000K-5500K?
Sorry, it was general question. Specifically, S2+, M2, M21B, L21B.
currently ,green coating for S2+ M1 C8
Which gaskets are best for 519A?
Hi Simon
Can upgrade 4x18a driver to 25A ?
Simon, thanks for all you do.
Having all the extra modes might mean less with UV or deep red. A big reason I want 12-group or biscotti is so that I can turn off mode memory. Mode memory is a deal breaker for me with normal lights. That goes double with UV. Please consider offering 21700 lights in UV and deep red with 12 groups or biscotti.
7mm 3535 gasket
9mm 3535 gasket
Ready to produce FET driver 25-30A
I have 12groups driver for red light in stock .
But strobe or SOS is useless for UV light ,
here is 21700 UV flashlight ,M21A SBT-10X-UV
