I ordered one in black/orange aux/4000K on their AliExpress store. I was waiting for something warmer than 5800K-6000K. I hope the one I get also has 90 CRI and isn’t below 4000K.
When I click the link for the 4000K version on Aliexpress I just get a message saying it can't be delivered to Germany. That's weird, I ordered from Wurkkos without issues. Do you want my money or not? xD
Mine should be here tomorrow. Looking forward to it. Will post a few words once it is here and I have played with it a bit.
From the pics, I am already loving the size.
What is wrong with the clip?? (ahhh… the oft hated bi-directional clip) Same type on my current favorite 14500, the SP10 Pro. Not a favorite of mine, but handy in certain situations… and it works fine.
It’s a 2-way clip - yes, they’re the fad that all manufacturers seem to be sticking on their lights these days, but I hate them. The only advantage a 2-way clip has over a 1-way clip is that you can stick it on a ball-cap. But if you’re like me and don’t wear ball caps that benefit is completely lost … a good 1-way clip should always be better.
The extra bend of 2-way clips sometimes gets caught on things in a pocket when the light is withdrawn from a pocket. I haven’t checked to see if that is an issue with the TS10’s clip, but it was an issue with the FWAA’s clip.
The bottom of the TS10’s clip lacks an angled bend to allow the clip to ride up over the edge of a pocket or belt when the light is clipped to something. Result is clipping the light onto anything is a 2-handed operation: one hand to lift the end of the clip up, while the other holds the light. This is inherently less convenient than a clip with an angled lip at the tip to allow the light to be clipped to something with just one hand.
If you only ever use your light bezel-down, the extra bend of a 2-way clip means extra unneeded weight is being carried around.
If you only ever use your light bezel-down, the extra bend of a 2-way clip means the clip is sticking out further from the flashlight body than needed, making the light less compact.
Have you ever hooked the end of your (non-bi directional) clip on something like a shirt tail or coat and accidentally pulled it out? I have, a bunch of times and lost lights because of it. The rounded leading edge of this clip looks like it is far less prone to getting snagged on something and pulled out of your pocket.
