With the base being flat, how did you fix the magnet, any chance of some pics, did you drill a hole in the base, what magnet? Would like to do similar to mine.
Thanks It’s not too bad to live there There are regular shipping to and from Mauritius but yeah some sellers do charge a price for shipping.
Unfortunately, I’ll have to pass the lantern for now. Our currency took a 42% depreciation against the Dollar and shipping is making the deal not that appealing. Pros and cons I guess!
Sure thing, it sounds great to me after reading about it. :sunglasses:
That is a real hit your currency took.
But you’re right… Pros & Cons. Hopefully you can get one in the near future.
Best regards….
I used a Nite Ize Steelie Tablet magnet I had lying around. It has sticky foam tape on the back. They are discontinued now.
If I were to buy a magnet specifically to use on LT1 Mini, I would choose this one and stick it to the bottom of the tailcap with some double sided foam tape. That would certainly work.
It also MIGHT be possible to glue one of these inside the tailcap underneath the spring. I’m not certain it would be strong enough, but it may be worth a shot.
Thanks for the magnet info! I just ordered my two minis (a lower case m seems appropriate). I live in the boonies, without the best internet. So, what kind of foam tape do you recommend, and where might I be able to get it (I’m in the Bigfoot Country of Northern California)?
AFAIK they’re all kind of the same. “3M VHB” is the big brand name kind. I bought a generic roll of the same looking stuff at my local Walmart last year. Before that I had a roll from Gorilla that was exactly the same thing.
I ordered a bunch of these magnets and tried sticking one in the tailcap of my LT1 Mini. Install was super easy, I just unscrewed the tailcap and fished the magnet through the gaps in the spring. Now it just sits there under the spring with no glue or anything.
The strength is OK. Holding the light upside down on a horizontal surface is no problem. Vertical surfaces are a challenge though. There’s usually just not enough friction to prevent the light from sliding down the surface most of the time. These pics on vertical surfaces are just a couple of spots where I was able to get it to stay put after careful placement. It stayed put just fine on a thick rusty piece of steel.
This also works on LT1S to a similar degree of success: strong enough to hold upside down on a horizontal surface, but not strong enough to hold on a vertical surface.
You mention “some of those magnets”. Can you tell me the specific one that you used that fits? K&J stocks hundreds/thousands of magnets.
Maybe where you got them?
I ordered some of the flat ones to use with double sided tape, but this looks a lot cleaner.
