TaoTronics 12" Rechargeable Floor Fan
Got mine today as well…and what a strange journey it took (quickly!). Ordered directly from their site (assumedly California). UPS tracking number shipping from Texas. Tracking showed it to be out for delivery. It arrived, but in an extra large Amazon box and delivered by Amazon. And my name/shipping address was NOWHERE on the box! A couple of shipping labels that were totally irrelevant…and stickers with QR codes, which maybe is how they got it to me? Bizarre. It did have a lithium shipping sticker on the fan carton, but nothing on the Amazon box itself…and no, no indication anywhere in the manual or on the unit about lithium cautions….dumb.
Initial impressions are very good! Blade is indeed 12”, cage is about 15”, pretty sturdy plastic and nicely done (no sharp flashing or sprue). Overall dimensions to the widest points with the cage vertical are 19” x 19” x 9.5”. The top handle is about 2.5” and removable via two screws. Cage comes apart easily for cleaning (haven’t done it yet but it looks like 4 screws and the entire back metal cage/motor/control panel will separate, manual indicates similar). The tubular base has a footprint of 17.5” x 9.5” and some pretty nice flexible plastic feet that are stable and appear to isolate vibration really well. I say that last part because the blade appears to be really unbalanced and yet there is surprisingly no felt vibration anywhere on the unit! May check that more thoroughly later. The two side knobs do a good job keeping the cage position but I’m not sure how their grip will fare over time.
Weight of the unit on a hanging digital scale is 9lb 3oz (4.17kg).
Interesting behavior out of the box - not sure if that’s affected by the low state of charge but after it finishes charging I’ll check again, ran it via the wall wart to check things out. The motor is very slow to start up. Max settting is right next to the click from Off, and at first it looks like the blade isn’t going to move…then it creeps up slowly until it reaches full speed. Takes about 15 seconds to get there. On shut down the blade stops in 3-4 seconds and you can see the jerkiness of the DC motor. Not all smooth and silky long easy spinning like an AC fan motor in good condition.
At 25% power it’s not silent but very, very quiet….on lowest it’s close to silent but still moves decent air. 50% up to Max is what most people might call noisy but I call it normal fan air flow…it’s not bad at all. The blade is a pretty thin cheap stamped, channeled and riveted affair so some turbulent noise is to be expected (like the majority of fans these days). I didn’t expect it to move so much air but it’s pretty impressive, and I think equaling a comparably sized AC fan, which is awesome!
About the only thing that might be a negative (assuming it never goes up in flames) is that the control panel lighting/charge leds are in the rear where you can’t see them in most situations, so you may not see it running low until it quits. And it won’t take an AC extension cord for power, just the wall wart, but that does seem to work nicely for powering it.
I don’t think I’d ever pay the $125+ or even $80 pricing for this, but it really does seem to be well made and performs nicely. Definitely a no-brainer for $50 or less (and a heel-kicker for $20!!). Half expected to see an order cancellation today since the tracking on UPS early this morning hadn’t moved since they created it, but here it is.
And thanks for sharing this, tammap! Wasn’t in the market but what a great purchase. :slight_smile:
I guess I’ll find out later myself, but did you happen to notice if the fan speed slows down near the bottom of the charge, or is it steady and then cuts off? Curious about the controller…clearly they have some smart-ish things going on in there.
These fans were probably in Amazon warehouses — It’s my understanding, products that don’t sell within a certain time frame are thrown in dumpsters— I think this is where the Vipon Deals were created from — I bought a Westinghouse 9500DF generator for $775 last month, now they’re $999 and were as high as $1199
Yes…looked at the box and peeled of blank cover labels and it had amazon stickers all over (a few red ones…). I’ll bet these were stock pull after Amazon gave them the boot. Must be some collusion still afterwards with the FBA contracts. I’ve heard that Amazon can really stick it to vendors badly when things like this happen (even less severe infractions) to the point that the sellers can lose product AND cash in holding accounts and not be able to recover them.
After a full charge, all behaviors are the same. Nifty fan here. I think I’ll hold off on disassembling for a peek at the cells/circuit unless I get a wild hair this weekend.
I only ran it down to the red light; was still running when I unplugged it; the first time I ran it on variable speeds; the 2nd time on low; there was no noticeable change in speed.
At the 2nd test I let it run for about 5 min on the red light; it was still running when I unplugged it.(turned it off,not unplugged) :person_facepalming:
Ordered a fan from Taotronics on the 18th, received a shipping notification on the 21st, and just received a large empty Amazon box from UPS. I picked it up as soon as the driver put it next to my door, realized it was empty, told him so, cut the packing tape and showed him there was nothing in the box (just a bit of brown packing paper).
Driver took the box back, marked it as “Rejected”. I just left a contact message for Taotronics requesting an immediate refund. Not going to give them a second chance. Glad to hear some of you actually received your fans. Amazing that someone actually thought they could get away with shipping an empty box.
I ordered three fans.
Today, I received one of them.
One is scheduled to show up tomorrow.
The third one hasn't shipped yet.
I received a full refund from Taotronics less than 12 hours after making them aware of the problem. Their response was “It appears that Amazon shipped an empty box by mistake.”
Really wanted the fan, but at least the customer service was good.
I received my fan yesterday. Wish my second orders didn’t canceled. My fault for was indecisive in pulling trigger on multiple units at that price.
mine was cancelled :frowning:
edit:
I just got a fan in the mail, addressed to just my first name. Thanks for the free fan. Couldn’t get it to run on battery even after charging for 10 minutes. Maybe it will take a charge overnight.
Wow……with $20 oopses and then free fans it might be hard for them to stay in business! lol.
Battery isn't taking a charge after 1 hour. See no battery indicator when unplugged no flashing when plugged in. Disassembled the unit. On the motherboard plugged the dc-in connector to the battery terminal and turned it on, verified that works so ruling out motherboard issue.
Guessing one of the batteries of the bunch is dead and its not giving enough juice. Reading 18.6 on multimeter where red/blue wire connector is on the battery. Removed battery cover. Here's some pictures. It is 7 cells total. 4 + 3.
My experience ends here, please advise what a good next step is toward the goal of getting battery power working.
I got my two other fans today, for a total of three.
My order is complete.
I'm charging one of the fans right now.
(You have to charge them for four hours before you use them.)
Thank you, tammap, for the heads up on this deal.
I got to test my fans this afternoon when my grid power went out. My fans worked flawlessly for two hours until power was restored.
I am very pleased with my fans.
IIRC it read 13.4 on the board bat points, I’ll doublecheck later. I did plug the ac plug into bat plug and that worked fine. Here’s a bunch of photos. Any idea how to disassemble such a pack? I’ve solder and a rework station to work with but am weary of giving more than a short heat blast to the battery (which didn’t have effect).
This fan was free so that’s why I am bothering to do this. I’ve tested each cell and have the following values:
As my values are different than the numbers you propose and I am a noob I will explain that the way I got these values was by touching the black poker to the p- and the red poker to the B+, and later I stuck it underneath the cover to touch the battery directly as there’s only 6 points on the board but 7 batteries.
I presume I need to get the 04.4 battery charged and the rest will start working. But also I’m a noob and maybe that’s how it goes because of its position in the chain. I also and am not certain if the battery needs to be disconnected from the pack to be charged/conditioned or if that can be done by connecting leads directly to its ends.
Thanks for bearing with me I know I should learn this stuff and avoid a headache but until I do to keep things moving your assistance is appreciated.
Please enjoy your time here, lightsout!
That looks like three cells are overcharged and four cells are completely dead. All cells are definitely not recoverable and should be disposed safely.
Meanwhile the photo got updated. Please dispose the battery at a proper recycling station. It would be too dangerous trying to repair the battery pack for someone without the required knowledge.
So I’ve revived a few battery packs which have a BMS, and in my case the cells were severely discharged, but there wasn’t any single cell that was bad. Simply charging the entire pack slowly was sufficient to revive the pack.
The voltage values you have posted are not useful, because the BMS appears to be interfering with the readings, and they don’t really make sense.
I have found though that most BMS have a B+ and B- that complete a circuit with the battery, and if you can tap into those terminals, you can trickle charge the battery pack with the right charger. I have a few RC lipo chargers that are practical for this purpose, since they allow precise control of the amps and voltage.
Now based upon the picture of the BMS, I have an idea on where you would have to connect the charging leads, but without the right charger I’m not sure if it is a good idea.
