Sorry the champagne, purple, blue, green and grey these colors are on hold for now.
Because our PMC and warehouse partners were complaining that we made too many tags at the same time on TS10, which would affect the production and storage of other products.
Just for now, black+red+white, 4000k+6000k, red/blue/orange/green, we have 3*2*4=24 style models.
Including the allocation of raw materials, it is also necessary to re-run the audit meeting to make a decision.
We have ordered one set of new H10. It should be available tomorrow.
Then ready to find the specific reasons for this problem through a large number of samples collection.
I love how much you communicate about this, you're really doing this the right way. Other flashlight manufacturers should take notes on how to do this kind of problem solving.
Many thanks Jon. Hope you’re well. I haven’t been in for a while, we have pretty much zero data signal where we’re living in the camper, it’s both a blessing and a curse. Even a phone call involves walking up a hill to scrape a bit of signal out of the sky On the other hand, life is simpler surrounded by nature.
Torch ordered, and I threw in a silver with blue aux for good measure.
Finally got a TS10 and I have to say it’s the nicest cold white flashlight I’ve seen so far. Still have a cold white B35AM to reflow and compare, but these CSP emitters are quite nice. Still prefer warmer temps though Nice design as well, feels good in hand. Nicely done Wurkkos!
Thank you Streamtronics for your support always.
Everybody’s questions and suggestions are very precious for us, which will become Wurkkos’ power to move forward, make us higher, faster and stronger.
No…as said, it’s totally fine. The driver is a good one and the light as a package is made to handle what you can throw at it. That, but also those Samsung emitters are the “usual” types that are used in most lights and we have been using and abusing for over a decade as “we” began to push emitters harder, challenging the datasheets’ max figures, etc. We have lots of experience and tests with that one and most other emitters. These little micro chippy smd emitters from Latticepower don’t have that testing that we’re aware of, and they’re also constructed differently so they can’t handle as much heat and/or need probably more attention to heat dissipation than what we give other emitters/flashlight designs in general. But that said, we still don’t know for sure why one emitter in one light failed (we know that Zumlin believes his similar Nichia E21A emitters that he swapped into his TS10 host failed due to a poor quality reflow (soldering) and another failed after being toasted too hot on his hotplate…so not much to arrive at any conclusions here, and other people (including myself) are turboing this light with an H10 cell just fine so far).
Seems to be a lot of confusion and possibly some misinformation floating around the internet right now because of this as to cells and circuits. But generally, with most light designs and healthy available cells to buy, it’s not a big issue - just some differences in light output for some. We don’t know fully yet about the TS10 but your D4SV2 will be happy with anything you can put into it.
As a side note example, when you ordered that light from Hank he matched the driver design/output with the emitters you picked. If you had picked something like the E21A or 219B emitters, he would have used a different driver that puts out less current because those two emitters don’t like the same amount of heat that other emitters can cope with. Most light designs take all of this stuff into account and are tested for awhile before being sold to the public, so what you get should be fine and if there are special cautions they’ll usually state such (like no 14500 in a light designed for 1.5v AA cells…using matched high drain/low resistance cells in a multi-cell light…protected cells in a light that uses cells in series instead of parallel…etc).
