【TS10V2 Al available】Wurkkos "slender waist" TS10v2 aluminum version available with black,green,orange
I have one that was received with glue in the tailcap and one that was not. I have read that they should all be glued, though.
6.30th 03:00 for PST
It’s glued like the bezel.
When the tail cover is removed, professional tools are required to reposition and install the spring.
If it affects your normal use, please told customer service and show us the specific problem.
We will refund or send new one today.
I haven’t tried removing the tailcap, but I did remove the bezel.
It had a small amount of blue threadlocker. It was easy to unscrew the bezel by applying grip tape to the head and bezel for extra leverage. If the tailcap is glued the same it should be fairly easy to remove.
How is the current draw differ between the aux LED color?
see 【TS10V2 Ti available】Wurkkos "slender waist" TS10 titanium version will available on 23th,Sep - #131 by thefreeman
Hey, we haven’t even received the previous batch. :slight_smile:
I even haven’t received shipping notification from aliexpress for the second batch 4000k ones!
I have not either, ordered first day they dropped.
I'll wait for now, see if they come out with a linear driver (shouldn't take too long, they're easy to design) then when they manage to upgrade the driver I'll buy two (good & evil, silver with ice blue aux & black + red)
I totally missed this one - when will there be more?
Primarily looking for 4000k and ice blue secondary.
Have anybody measured the parasitic drain of TS10 HI AUX / low aux / off aux ?
There is a this thread on reddit
https://www.reddit.com/r/flashlight/comments/vq2w2n/my_ts10_went_from_42v_to_34v_in_80_hours_with_no/
I took some measurements of the drain of my TS10 with orange aux before.
Aux off: 5uA
Orange aux on low: 123uA
Orange aux on high: 7.8mA
There seeems to be a problem with low voltage protection as mentioned in that reddit thread.
yes and LVP, as the user on Reddit said their battery was @ 2.4v
my sample I hadn't tested, but because the orange auxiliary LEDs are So Bright, I have kept my aux LEDs on low and didn't notice the drain at all.
Hi, ¿Could you show us some real photos of the TS10 in silver. We haven’t seen any yet.
the problem with button aux and switch lights, is that they are not linked to LVP. So running the TS10 w Aux lights on High 24/7, without doing any battery checks, will drain the battery below 2.5v in about 3.5 days.
imo, the non firmware reflashing solution is not to run the Aux on High… and check battery voltage every few days.
I cannot reflash my Anduril lights. My iMac is not compatible with the software.
That comment isn’t up to date. indicator_led_update() disables the aux LEDs when the voltage is too low. If it really doesn’t turn off the aux LEDs, there must be another reason.
The comment by gchart is from just 11 hours ago, here is the link
the issue also exists with other Anduril lights that use Aux…
maybe Anduril has a problem with switch lights not accessing LVP, instead of Aux lights? (I think I read somewhere that TS10 aux are actually switch button lights, which is why they dont turn off when main LEDs come on, and actually get brighter at higher main LED output)
I will contact him because that comment in the code makes no sense.
edit: D’oh! I had just looked at my fork and there I had refactored the aux LED handling which fixed the LVP bug by accident. :person_facepalming:
good point,
if I did the math right, I think they could last 305 days on low, as opposed to 5 days on high?
even w LVP, running on high mode seems not ideal
I do not understand, are you saying you only fixed it on your own light?
Does the aux light no LVP bug exists in ALL Anduril lights, not just the TS10?
except whichever ones this refers to?:
“LVP while asleep: With aux LEDs getting quite bright lately on some lights, it is important to make sure they won’t discharge the battery too far. So I made low-voltage protection work even while the light is asleep in standby mode.”
