My eyes!
My eyes!
That’s one that’ll get through TSA no prob.
Btw, how much were they going for? For some reason, I really want one.
Looks like the Hello Kitty wanted a foldable cake knife. :person_facepalming: :laughing:
There’s also a “”Warrior Buffet”:https://www.bladehq.com/item—Boker-Kalashnikov-Warrior-Buffet—142783” :question: :partying_face:
I’m usually pretty good about keeping my knife blades clean after use. I got a little careless and left a thin bit of debris on my CRKT Squid D2 knife blade. It was on there for probably about 8 hours. When I cleaned off the blade, I noticed there were some stains. Yep, it’s real D2 alright. There had begun some surface level oxidation. Using a scrubbie didn’t get it off. I had to resort to using some silver polish with a paper towel. A bit of scrubbing for a minute or two—stains are now gone.
I’d seen a few other techniques when searching around. I’d avoid using steel wool as that will scratch the steel somewhat, which can ruin a polished or stone washed treatment. Naval jelly is supposed to be a good method. Also a polishing compound like simichrome.
Anyone else use some other techniques to easily remove rust stains from a D2 blade?
WD-40 works well for light rusty
I've had good results from FLITZ ...might be worth considering
Flitz is great for getting rid of rust and pepper spots on non stainless steel. Bar Keepers Friend is also good for rust also.
On my non Stainless knives, I usually will coat the blade in froglube and let it sit for a while before wiping it off, seems to give some protection to the metal later during use, if the knife will sit or be stored I coat it in wd40 specialist corrosion inhibitor.
For cleaning CLP or froglube work well
And for light specks of rust, flitz is good.
I forgot to mention I also give my knives a light coating of Camellia oil after a Flitz polish....acts as a rust inhibitor too
xevious….
try Fine Brass Wool.
just like steel wool
but softer scrubbing.
Sounds like Flitz is the popular solution. Will be getting some. The silver polish worked and so far the stains are not returning but it did require a few passes to finally clean them off.
Hey TD, I’d never heard of brass wool before. Sounds interesting & will make a point of picking up some — thanks!
Froglube sounds interesting, PT. I wonder if it’s anything like naval jelly? I do liked the idea of being proactive & putting on some kind of coating periodically to reduce staining of D2 blades.
I don’t think that frog lube is very similar to the naval jelly.
Frog lube is a bio based product and it’s food safe.
It’s sold as a eco friendly gun cleaner and lube
“Navl Jelley” is a rust remover, it does not prevent rust.
I think Naval Jelly and Coke or Coca Cola, have Phosphoric Acid,
Here is a nice video comparing a few rust removers:
You are correct on the Naval jelly but Coke (coca cola) is Carbonic acid from the carbonation.
Coke, Pepsi, and a few other sodas do in fact contain phosphoric acid. It makes them more acidic than what you’d get from just the dissolved carbon dioxide in plain seltzer.
Hello guys and girls.
My review of the most extreme parts of the Brother brand!:
Chinese Knives: Quad review: Brother 1615, Brother 1605, Brother 1612 and Brother 1603
Civivi Relic
You already know that I loved the SRM 7228, you have it reviewed both on my blog and on my YouTube channel, but I always thought that I would love to have the same model in a larger size.
Well that time has come…
I hope you like the comparison.
Link: https://chinese-knives.blogspot.com/2022/10/review-srm-7228l-gw-vs-srm-7228.html
