【TS10V2 Al available】Wurkkos "slender waist" TS10v2 aluminum version available with black,green,orange
good point,
if I did the math right, I think they could last 305 days on low, as opposed to 5 days on high?
even w LVP, running on high mode seems not ideal
I do not understand, are you saying you only fixed it on your own light?
Does the aux light no LVP bug exists in ALL Anduril lights, not just the TS10?
except whichever ones this refers to?:
“LVP while asleep: With aux LEDs getting quite bright lately on some lights, it is important to make sure they won’t discharge the battery too far. So I made low-voltage protection work even while the light is asleep in standby mode.”
Yes, I had fixed it in my own version long time ago and forgot about it.
The missing LVP affects all lights with “simple” (non-RGB) aux LEDs. The quote is about RGB LEDs.
I just got the shipping notification for my red body 4000k ts10 with blue aux. Hopefully they are all on the way now.
It seems every version of this light is sold out.
for this price its a steal!
Thank You Very Much!
so, Anduril has No LVP for non-RGB Aux lights… wow, it took us a few years to realize that.
The problem went undetected for a LOOOONG time and is Not specific to TS10.
And the problem with high battery drain is Only for High Mode Aux lights.
Low mode aux lights last 1-2 years, depending whose drain rate data we use.
about 2 years on low
about 1 year on low
Hopefully I got all that correct.
so, my takeaway is:
Do NOT use High Mode Aux Lights 24/7
as they will drain the battery in less than a week.
(plus it will overdischarge since there is no LVP)
Even if LVP was working (I have not seen a fixed hex file for that)
(there is a hex file to turn off the aux lights when main LEDs are on thanks to zumlin),
but no Update will change the reality that High Mode Aux will Still Kill the Battery in less than a Week
High aux mode isn’t very practical. Other lights have had this issue. I vaguely even an 18650 in an Emisar D4v2 would drain in something like 5 or 10 days on high aux.
Much better to just use low aux. it’s bright enough to find the light and won’t drain the light fast.
Right, I only use high AUX overnight when I’m sleeping in an unfamiliar setting… like an alleyway or someone’s yard.
While I don’t have a TS10 yet to test it on, I have patched the aux LVP for non-RGB lights and tested it on a different light (my FT03). I have sent the firmware to Wurkkos for testing. So this should be addressed going forward.
I’m kinda shocked we’ve been without this for so long. But yeah… Just don’t keep your small lights on aux-high!
thank you…
suggest also patch aux lights to turn off when white light is on.
Yup, I’ve already patched that one and sent it over to Wurkkos.
Does this affect hank lights? If so, this gives me an excuse to go back and reflash all my lights to anduril 2
Eh, I dunno. Most Hank lights with aux are RGB, right? Those should be ok I think. But honestly I’m not sure how Anduril (1) handled it, it could be different.
This leads to a complex situation. Now Wurkkos has to link to your specific fork to be compliant with the GPL.
Sorry my man, the third batch needs to wait until 7.25th after.
And TS10 will be also sent to Amazon this time.
No problem my man.
Here are some real photos with TS10 in silver.
Please check it
Was TS10 sent to US Walmart? Does it have the updated firmware by gchart?
I just tested your patch on my TS10 and I can confirm that it has fixed the LVP bug. The aux leds now turn off when the voltage drops below 2.8V on my dc power supply.
Thank you for fixing it so quickly.
Great, thanks a ton for confirming! :+1:
Thank you very much for the photos, it looks very nice.
